Thinset - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-02-2011, 09:04 PM   #1
Rewards Points: 154
thinset
what is the best thinset to use under cement board?
the stuff that flexes a litle or just the normal stuff?
awdblazer is offline   Reply With Quote
Old 03-02-2011, 09:17 PM   #2
Retired Moderator
Rewards Points: 7,174
You may use a modified thinset--the powdered kind.--Use the search button there is a blog by Bud Cline called" Mud what is it?"
Mapei and Latacrete are two well known makers--go to their web sites and read up on thinset.
Come back after you do some research at their sites.
---Mike---
Old 03-03-2011, 08:14 AM   #3
Rewards Points: 154
which would be best for thinsetting down the cement board?
http://www.homedepot.ca/webapp/wcs/s...k=P_PartNumber
or
and what cement board durock or wonderboard?
thanks!!
Old 03-03-2011, 03:15 PM   #4
Retired Moderator
If you are going to use Custom Blend--use Versabond---That is a modified thinset--also good for the tile.
Old 03-03-2011, 03:18 PM   #5
Rewards Points: 154
they dont have versabond, only the flexbond or is that the same stuff?
Old 03-03-2011, 03:24 PM   #6
Retired Moderator
That is their most popular product. I did not find it on the website---but they have it.
There is no need to spend the extra on the Frexibond.---call the store--I know they have it.-Mike--
Old 03-03-2011, 03:43 PM   #7
Retired Moderator
"Mud" What Is It? - Kitchen & Bath Remodeling - DIY Chatroom - DIY Home Improvement Forum
Good reading.
Old 03-03-2011, 03:44 PM   #8
Rewards Points: 154
flexbond is not worth it? cause i have one bag of that before i knew i was going to be doing cement board
so since i have the flexbond and i dont know if i can return it without a receipt should i use that first (bonding cement board to subfloor) or for tiling?
i wonder if they would let me return it without a receipt
Old 03-03-2011, 03:50 PM   #9
Retired Moderator
You didn't say that you had it already---it's a fine product---go ahead and use it--Mike---
Old 03-03-2011, 07:54 PM   #10
Rewards Points: 154
sorry yah i have a bag of the flexbond, but if you say the versabond is good to i would rather use the versabond under my tile and under the cement board
1/4 square notch for laying the cement board?
Old 03-03-2011, 09:15 PM   #11
Tileguy
JazMan's Avatar
Rewards Points: 750
Versabond and Flexbond are the same "type" of thin set. Flexbond is better. I don't know how much tiling you'll be doing. If I need one of each, I would use the cheaper under the board, and the better to set the tiles. When did you buy the Flexbond? Can you find the code stamped on the bag?
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
JazMan is online now   Reply With Quote
Old 03-04-2011, 06:30 AM   #12
Rewards Points: 154
i bought it about 3 months ago
Old 03-04-2011, 09:29 AM   #13
Retired Moderator
If it was stored in the house you should be fine.---The garage--it's probably shot.
Powders must be stored in a dry place or the cement will be spoiled.
Old 03-04-2011, 11:43 AM   #14
Rewards Points: 154
returned it today, will get two bags of versabond as it is about the same price for the two bags as the one bag of flexbond
also going to get durock
The Following User Says Thank You to awdblazer For This Useful Post:
oh'mike (03-04-2011)
Old 03-04-2011, 11:46 AM   #15
Experienced
Jackofall1's Avatar
Rewards Points: 2,102
Thinset is like everything else in life, you get what you pay for.
Mark
White thinset and Gray Thinset, does it really make a difference.. yummy mummy Tiling, ceramics, marble 25 02-03-2012 11:00 PM
questions about thinset ponch37300 Flooring 16 03-16-2011 11:45 AM
Is thinset always necessary? 123 Tiling, ceramics, marble 2 04-29-2010 07:01 PM
Fortified Thinset poolecw Flooring 4 10-31-2008 07:06 AM
Thinset application question poolecw Flooring 2 10-15-2008 03:51 PM
