Slate Installation - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 07-21-2011, 12:58 AM   #1
slate installation
If I am installing slate on the outside of the front door step up to the aluminum threshold, is it better to grout the space between the slate and aluminum threshold or should I caulk it? The door is protected and not subjected to weather.
808kuri is offline   Reply With Quote
Old 07-21-2011, 09:32 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 750
Grout will crack 10 minutes after you've done it. Caulk it.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
The Following User Says Thank You to JazMan For This Useful Post:
808kuri (07-22-2011)
slate walls timbo59 Building & Construction 5 12-06-2010 09:46 AM
slate tile installation donnavan Flooring 1 05-04-2010 07:33 AM
Plasma TV over Slate jrcrum Home Theater 8 12-16-2009 04:59 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 12:19 AM
Advice and help on slate floors adamsela Flooring 1 10-04-2006 04:23 PM
