Regrout Tile Shower - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-07-2012, 12:26 PM   #1
bryanp22's Avatar
Rewards Points: 346
regrout tile shower
Hi,
I have a tile shower that the tile isn't our favorite, but we don't want to deal with the mess of removing everything and starting over at this point. THe shower is difficult to clean though as some of the grout has gradually worn away from the many years of use. To touch up the groupt what do people recommend as it is unsanded grout. Do I need to scrap the old grout away? I would like to regrout, and then seal the grout lines.
bryanp22 is offline   Reply With Quote
Old 03-09-2012, 10:58 AM   #2
unsanded grout is for small gaps, so that is most likely what you want to use. Yes you need to remove the old grout.
bkeech is offline   Reply With Quote
Old 03-12-2012, 07:02 PM   #3
mike owes me $53 dollars
Tech Dawg's Avatar
Depending on the grout joint size, you could also look into using Laticrete SpectraLock grout and leave back 10% of the powder. With SpectraLock, you wouldn't need to mess with sealer.
Tech Dawg is offline   Reply With Quote
Old 03-12-2012, 09:07 PM   #4
bryanp22's Avatar
Rewards Points: 346
What do you mean 10% of powder?
Old 03-13-2012, 05:05 PM   #5
Tech Dawg's Avatar
With SpectrLock, the powder is separate from the epoxy mixtures so you would mix the epoxies and then add the grout powder but don't use 10% of it. It will make it buttery and easier to work with.
Todd
www.aloneeagle.com
Tile or fiberglass shower? Proby Tiling, ceramics, marble 18 07-26-2010 04:49 PM
Shower tile specifics re: hair coloring Pammylu Tiling, ceramics, marble 4 06-05-2009 02:32 PM
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 02:58 PM
Problem Glass Tile Shower robin2107 Remodeling 9 04-23-2007 08:19 PM
Building a tile shower ghostrider20 General DIY Discussions 2 03-01-2007 08:54 PM
