Plywood Versus Ditra, Or Both? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 12-13-2011, 04:34 PM   #1
Plywood versus Ditra, or both?
We're building a new home. Our subfloors are Stable-Edge OSB, and they have been nailed and screwed. In the rooms that we would like to tile, do we need to add plywood before the tiling? Is The Schluter Ditra membrane sufficient (without plywood) to ensure there will be no cracking? I would like to keep the hardwood and ceramic floors at an even level, and I don't see how that is possible if I have to add 5/8-inch plywood.
Ron 17 is offline   Reply With Quote
Old 12-13-2011, 04:50 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
DITRA can go directly over the subfloor if it is a minimum of 5/8"
You have two choices of DITRA. It comes in thicknesses of 1/8" and 5/16".
Old 12-14-2011, 08:57 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 750
The choice is not whether to tile over plywood, OSB or Ditra. I would not recommend tiling on plywood, and you can't tile direct to OSB. You need both otherwise concrete backer over the OSB. I like the Ditra route best though.
If your subfloor is installed correctly you will be good for Ditra as is. How thick is the OSB, the joists spacing, span?
If you wanna go 1st class why not install min. 3/8"-1/2" ply underlayment on all the floors, then Ditra in the tiled areas? Generally Ditra XL (5/16"), plus tiles = 3/4" hardwood, that's why they make it 5/16".
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
ditra over plywood n175h Flooring 4 12-10-2011 02:54 PM
Ditra & Travertine on Interior-Grade Plywood katyshuler Tiling, ceramics, marble 11 06-29-2011 06:28 AM
sheetrock versus plywood Steve Burke Building & Construction 4 01-01-2010 10:42 AM
Advice on using Ditra on Plywood against Backerboard fjlcisco21 Flooring 5 08-10-2009 06:56 PM
Installing Ceramic tile: Ditra over Vinyl or rip out and use 5/8 Plywood? ppieda Flooring 2 10-05-2007 11:01 AM
