Mortar Under Tile Remains Wet--why? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 10-17-2016, 03:43 PM   #1
Rewards Points: 4
Mortar under tile remains wet--why?
Installed new ceramic tile in a shower pan about two weeks ago and have not used the shower. Noticed a tile was not level and removed it in order to reset it. When removed, I found the premixed mortar under the center of the tile was still damp--as if I'd put it in only a few minutes earlier. Mortar around the edges was dry. That made me curious and I took up another few tiles--same situation: dry edges and wet center. Any clue as to what I might have done wrong?
chemdawg is offline   Reply With Quote
The Following User Says Thank You to chemdawg For This Useful Post:
BayouRunner (10-18-2016)
Old 10-17-2016, 04:37 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 750
Re: Mortar under tile remains wet--why?
You used the WRONG stuff! Remove all the tiles and get real "thinset" which ONLY comes in a bag.
My guess is that you missed reading the instructions which generally say this; Do not use on shower floors or areas exposed to prolonged water
exposure or steam.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 10-17-2016, 05:06 PM   #3
Rewards Points: 4
Thanks, Jazman.
Hmmm... What I used is a premixed thinset, but you are correct, the instructions do say to not use it for a shower floor. Also, in re-reading the instructions, I noticed this product is recommended for up to 8" x 8" tiles. We are using 12" x 12" and the manufacturer says to expect extended cure times. Thanks again.
Old 10-17-2016, 06:55 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 750
Darn Men..........They do it THEN read the instructions!
A word about the word "thinset" & "thin set".
Sometimes the term "thin set" refers to the method of installation where tiles are bonded direct to the substrate such as Plywood, backer board or other membrane. So thin set instead of thick-bed as in a real "mud job".
Where as the noun "thinset" by industry definition must be made from Portland cement. Portland products can not be pre-mixed and stored in a container as they'l harden in no time.
That thin-set you used in nothing more than mastic with a little sand added used for a thin set installation in certain installations. BTW, although it's no where as good as real thinset, it does cost about 3x more per square ft. installed. Next time leave it on the shelves to collect more dust.
Jaz
Tags
wet mortar two weeks
Tile lippage-acceptable or not? KC33 Tiling, ceramics, marble 10 12-04-2015 02:33 AM
tile over tile aflemi01 Tiling, ceramics, marble 11 06-19-2015 02:03 PM
failing mortar and decorative tile questions Windows Concrete, Stone & Masonry 6 12-10-2014 10:12 PM
exterior mortar mix for tile tabletop candoo Building & Construction 0 05-04-2012 07:33 PM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
