Looking For The Best Grout - Tiling, ceramics, marble - Page 3 - DIY Chatroom Home Improvement Forum
Old 03-27-2012, 02:01 PM   #31
Rewards Points: 312
Originally Posted by DIYNana View Post
Hopefully last question. What can I use over front of the tile to make it more stable when cutting? Would tape work? do I need to keep it away from the blade or can I cut through it and then remove after I put tile on the wall?
When you say more "stable," are you simply referring to the tile moving around on the sliding "fence?" If so, sure, use tape. I'd say something like cheap masking tape or something like that (not duct tape) would work perfectly fine. I found that cutting the mosaic tile sheets was easiest by putting a piece of cardboard under the mosaic sheet (so it has a flat/stable base), lining it up where I wanted it to cut, and sliding it through the blade to make the cut. The blade has no problem cutting through cardboard. I never taped the tile down myself, but just held it in place against the cardboard. The weight of the sheet and the wet cardboard kept things from moving around much when I did it.
NewHomeDIYGuy is offline   Reply With Quote
Old 03-27-2012, 02:27 PM   #32
the Musigician
DangerMouse's Avatar
Originally Posted by NewHomeDIYGuy View Post
it's amazing how much stuff I've learned thanks to this place.
Shhhhhhh, don't SAY that! They'll make you a MODERATOR!!!
DM
Old 03-27-2012, 04:01 PM   #33
[quote=NewHomeDIYGuy;886669]When you say more "stable," are you simply referring to the tile moving around on the sliding "fence?" ]
That was what I meant. Cardboard sounds like a good idea and may use a painters tape on top. Tiles should be here this week so Thanks to all.
DIYNana is offline   Reply With Quote
Can bad grout job be salvaged? wlsmith Tiling, ceramics, marble 22 11-14-2010 06:31 AM
Shower grout discoloration Teebadoe Kitchen & Bath Remodeling 2 11-03-2010 07:07 PM
Removing grout from top of ceramic tiles markdrum1 Tiling, ceramics, marble 3 09-28-2010 09:38 AM
Polyblend 'Grout Renew' - any experiences? spidrw Tiling, ceramics, marble 0 04-22-2010 12:37 PM
Tinting/re-coloring grout proofer Flooring 7 02-02-2008 10:59 PM
