Leveling Out Plywood Floor Before Tiling - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 08-05-2012, 09:21 PM   #1
Leveling out plywood floor before tiling
I am going to re tile my bathroom but when I picked up the old tile I found a rotted floor where the toilet was. I have since put down new plywood but there is a little lip on the edge of the new/old plywood. If I am going to put down backer board will I need to level out that lip or will the mortar and backer board compensate for the difference? The difference is small maybe 1/8" at most. Thanks for any advice!
adam.r is offline   Reply With Quote
Old 08-05-2012, 10:19 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 750
Adam,
1/8" is HUGE. The seams need to be within 1/32" of each other. Did you install blocking under the new seam?
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 08-06-2012, 10:30 AM   #3
Rewards Points: 17,912
Are you sure you used the same thickness subflooring?
Old 08-06-2012, 11:57 AM   #4
Jaz,
I may be wrong about the difference. I did put blocking underneath the new plywood and it is the same size as the existing plywood. I will post later what the actual difference is but let's say 1/16" is the difference. What could I do to compensate for this? Would the mortar and the backer board be enough to fix this? I would rather not have to take up the new plywood to fix this problem.
Thanks,
Adam
Old 08-06-2012, 08:08 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 750
Depending on the amount, how much was replaced, the lay-out, and which is lower, I might let the thin set under the backer do the supporting but put the fasteners in strategic locations to help things. In other words fasten the high side where the transition happens and not the low side for at least 8" or so.
If you placed blocking under the seams you should be able to get away with just a single subfloor. How big a piece did you install? New patch needs to rest on 3 joists, two is not enough.
Jaz
Old 08-06-2012, 08:53 PM   #6
Here are a couple of pics. I did the repair in 2 different sections. All of the new pieces are secured by all 4 sides with sistered joists and some perpendicular supporting pieces in between the joists. This is very solid. I just measured and at some points it is a little over 1/16" to flush with the old pieces.
Leveling out plywood floor before tiling-image-2143751826.jpg   Leveling out plywood floor before tiling-image-1726610220.jpg
Luan Plywood Underlayment BigJim Flooring 12 03-05-2013 04:41 PM
How to attach plywood to subfloor Billdd Flooring 6 08-05-2012 04:27 PM
OSB + Plywood = solid base for tiling? Denisrus Flooring 35 05-18-2012 11:13 PM
Tiling over plywood floor 3 season porch matt7125 Flooring 12 04-22-2011 06:22 AM
Leveling plywood helpless handyman Flooring 16 10-19-2006 11:46 AM
