Just Sealed Grout...water Absorbing? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 01-22-2011, 08:49 PM   #1
Just sealed grout...water absorbing?
Hey guys,
I just applied two coats of sealant to the grout in my recently tiled (ceramic) shower stall. The instructions on the bottle say 2 hours after the application, water should "bead" up and "not appear to be absorbed". I just tested this and it appears that the water is still being absorbed into the grout(no beading).
I'm thinking I need another coat, any thoughts? Should the water be beading?
jakes29 is offline   Reply With Quote
Old 01-23-2011, 08:53 AM   #2
ccarlisle's Avatar
Sometimes the water beads up, sometimes it doesn't, don't expect yours to 100%...try another coat, won't hurt. Depends on the sealer tho, as there are good ones and not.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 01-23-2011, 12:27 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 750
Most people have a misconception of what grout sealers can do. So don't feel bad.
As our Canadian friend mentioned sealers vary in quality. So, just go ahead and apply more until it won't absorb any more. Sealers DO NOT seal the grout from moisture or stains. They slow down how fast the spill soaks in, it will not make grout impervious.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 01-23-2011, 01:00 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Keep sealin'!
XXX
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Well Water snuggles2010 Plumbing 3 04-13-2010 01:36 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
