Installing Tile But Not Sure About Material Under Carpet - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 05-02-2020, 10:23 PM   #1
Rewards Points: 4
Installing tile but not sure about material under carpet
I a looking to put tile down where I currently have carpet but after pulling the carpet up and expecting to see just concrete slab, I am seeing a thin layer of white material. This material is rougher than the slab and doesn't feel like or look like a paint. It feels more like a mortar. Question is, what is this and can I apply mortar and tile on top of it or do I have to remove it. Any help would be appreciated.
RobM701 is offline   Reply With Quote
Old 05-03-2020, 06:01 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 4,338
Re: Installing tile but not sure about material under carpet
Quite possibly it is SLC (Self leveling compound), and there was a dip in the floor at one time. It is grainer than concrete. You should not have a problem applying 1/4" of thinset on it and laying your tile.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 05-03-2020, 08:03 AM   #3
Rewards Points: 4
Thanks. It's covering the entire floor and was put down when the home was built in '95. Just to be safe, should I put down Ditra?
Old 05-03-2020, 08:09 AM   #4
Naildriver
chandler48's Avatar
If it is all over the floor, it is DamTite "waterproofing". There may have been moisture problems before and the Previous Owner thought it best to "seal" the floor, which he didn't, but that's water under the bridge (no pun intended).
If you don't have cracks in the floor, the floor should be good to lay tile on directly. Ditra is an isolation membrane that keeps the tiles from cracking when the concrete expands, so you may not need to spend that extra money. However, if you feel like you should, Ditra is a great product.
Larry......
Tags
concrete , slab , tile
