How To Adhere Tile As Decoration To Wood Bureau Drawers? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 01-27-2010, 03:53 PM   #1
How to adhere tile as decoration to wood bureau drawers?
Hi folks..
I'm new to this site but so glad I found it!!!
I am revamping a bureau with faux finishing and want to adhere tiles to the outside of bureau drawers for an antique "look". No functionality here... just decorative accent. No grout will be used. Its just a finishing touch. Does anyone have any suggestions? Will Gorilla Glue work???
Thanks!
roccart is offline   Reply With Quote
Old 01-27-2010, 04:35 PM   #2
Retired Moderator
Rewards Points: 7,174
Gorilla glue is to sloppy( it foams up and pushes out as it sets)
I suggest 100% silicone caulk--A small dab of hot glue in the center of the tile will hold the piece in place until the silicone sets up
---mike--
Old 01-27-2010, 06:54 PM   #3
Thanks!
Thanks Mike!
Could I use the gorilla glue on the center of the tile (safe spread area) instead of hot glue? Are you refering to a glue gun with those glue sticks?
Old 01-28-2010, 11:00 AM   #4
Rewards Points: 5,348
Originally Posted by roccart View Post
Thanks Mike!
Instead of hot glue, masking tape would be an option. It needs to immediately hold the tile in place. No glue will do that.
Ron
Old 01-28-2010, 01:21 PM   #5
Masking tape????
Hi...
Are you sure MASKING TAPE will hold the tile down? I know I am a newbie.. a little green in areas of creative projects ...but masking tape???
Could the responder of the previous post please elaborate???
thanks
Old 01-28-2010, 01:34 PM   #6
Registered User
Termite's Avatar
No idea how masking tape would do this...Perhaps sarcasm?
I'd suggest liquid nails or silicone adhesive. I agree that gorilla glue is too messy as it sets, limiting its ideal uses to things you won't see.
Old 01-28-2010, 01:58 PM   #7
Hi...
thanks
The masking tape would be instead of the hot glue gun. This is assuming you were going to put the tiles on the drawers while still in the bureau. It would be used to hold the tile in position while the silicone sets. Not the way I would have done it. You wouldn't need the tape if you took the drawers out of the bureau and laid them, face up on the floor. Then the silicone would just set overnight and you're done.
While I've used sarcasm at times in the past, this was not one of those times.
Ron
Installing wood floors over saltillo tile Bloom Flooring 3 07-02-2009 10:42 PM
flooring frankiedog Flooring 7 12-05-2008 01:05 PM
Tile with a wood appearance? jerome8283 Flooring 2 11-15-2006 06:53 AM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
Tile Walls - Wood Floors - which goes first? MikeinBurien Flooring 1 03-04-2006 06:55 PM
