Gluing Porcelain Base - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 11-10-2011, 12:42 PM   #1
Doing a remodel in a bathroom, gluing porcelain base to wall with PL Premium caulk. In some areas the sheetrock has been patched, does the new mudded area need to be primed before gluing tile to?
PiersonPainting is offline   Reply With Quote
Old 11-10-2011, 03:49 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
PL Premium is an adhesive...not a caulk.
Probably not but it may be better. You could apply some PL and scald it with a putty knife. After that dries, then glue up the tiles.
XXX
Old 11-10-2011, 03:52 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 750
You're using what? Replacing 1-2 piece are ya? It may work anyway. I suggest applying a skim coat on the bare spots first.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 11-10-2011, 06:10 PM   #4
Yes Bud, I know PL Premium is not caulk, I realized my mistake right after I hit the submit button. I was going to place the thin set on the back of the tile, but after doing a little reaserch and youtubing, someone mentioned using this adhesive instead. Its faster and it can be used on tile, I don't see a downside.
Old 11-11-2011, 08:35 AM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Of course you do
You can edit your posts...unless your edit-button is burned out.
There probably isn't a downside unless your tiles are wet from sawing.
XXX
Old 11-11-2011, 07:01 PM   #6
Tiles will be dry.
Sink base vs regular base cabinets... J187 Kitchen & Bath Remodeling 3 12-03-2010 07:40 AM
Bathtub Porcelain Enameled v. just Porcelain amgdiy Kitchen & Bath Remodeling 13 10-12-2010 09:48 PM
how to nail base cap of baseboard molding conradA Flooring 3 06-23-2010 11:57 AM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
How to create a curved wooden base shoe? hayzen Carpentry 3 07-28-2009 03:29 PM
