First Time Tiling A Bathroom - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-25-2012, 03:46 PM   #1
Rewards Points: 113
First time tiling a bathroom
i bought 1/4 inch hardibacker. how much gap do i need between tub, backerboard, and tile. At threshold, if i have an 1/8 space from wall, tile will sit back 1/8 from threshold. how do i keep tile even to door? do i need any type water repellant like Red Guard? thanks
EFTHIM is offline   Reply With Quote
Old 03-25-2012, 03:50 PM   #2
Retired Moderator
Rewards Points: 7,174
One question at a time---
Is this for the floor or walls?
Old 03-25-2012, 03:53 PM   #3
Rewards Points: 113
Tiling a floor.
Old 03-25-2012, 03:56 PM   #4
Retired Moderator
That helps---Leave a gap of about 1/4" at the tub and walls---set the board into a bed of wet thinset and screw or nail.
Tape the seams with tilers mash AS you set the tile----
Old 03-25-2012, 04:14 PM   #5
Rewards Points: 113
The wall with the doorway. If i have a 1/4 inch gap for the backerboard, my tile will sit back a 1/4 inch from the threshold. how do i remedy this? i wanted to tile even with the wall and make a wood threshold that would meet the flooring. thanks for your help.
Old 03-25-2012, 04:16 PM   #6
Rewards Points: 150
You will want to install a tile trim like schluter at the door threshold and red guard is never a bad idea but likely unnecessary in your situation. I would return the hardi backer and purchase cement board, but thats just me.
OhioHomeDoctor is offline   Reply With Quote
The Following User Says Thank You to OhioHomeDoctor For This Useful Post:
oh'mike (03-25-2012)
Old 03-25-2012, 04:17 PM   #7
Pro
JetSwet's Avatar
Rewards Points: 502
Your cement board should sit on the lip that comes up from the tub for the walls.
JetSwet is offline   Reply With Quote
Old 03-25-2012, 04:45 PM   #8
Rewards Points: 113
the schluter product is fairly thin. does this address the 1/4 inch gap away from the wall. will this make up the difference? what schluter product do you recommend? thanks
Old 03-25-2012, 05:08 PM   #9
Rewards Points: 113
Old 03-25-2012, 05:10 PM   #10
Rewards Points: 150
You could use ditra if elevation is what you are talking about.
Old 03-25-2012, 05:18 PM   #11
Rewards Points: 113
i was going to use wood for elevation. the problem is the gap for the wall. if backerboard is 1/4 inch from wall tile will be an additional 1/4 from threshold. will it matter? thanks
Old 03-25-2012, 06:42 PM   #12
Retired Moderator
I'm a little slow in the head today---1/4" from the threshhold--and the wall--what are you trying to do?
Are you talking about thickness ? or height?
Sorry but I just can't follow what you are trying to do---
Old 03-25-2012, 06:59 PM   #13
Tileguy
JazMan's Avatar
Rewards Points: 750
He's talking about the perimeter gap and gap to the tub and marble threshold.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 03-25-2012, 07:05 PM   #14
Retired Moderator
Thanks Jaz----Splitting head ache for two straight days---sorry.
Old 03-26-2012, 01:28 PM   #15
Rewards Points: 113
The perimeter gap is correct. I didn't know the terminology. if the board sits back a 1/4 inch won't it effect the way door looks with regards to the tile? Is there a trick i'm missing?
Tiling my bathroom floor in the basement ambertrail Tiling, ceramics, marble 3 09-06-2011 04:23 PM
Tiling basement bathroom - remove sticky tiles? aldgagnon Flooring 10 10-25-2010 09:42 AM
Bathroom remodel - I think it's time to call in the pros for part of this mess StevePax Remodeling 6 12-26-2009 12:18 PM
Bathroom Tile - First Time advice wombosi Tiling, ceramics, marble 8 12-11-2008 08:08 PM
Tiling bathroom ivaiva Project Showcase 3 08-30-2008 08:24 AM
