First Time Tileing Shower - Need Tips - Tiling, ceramics, marble - Page 3 - DIY Chatroom Home Improvement Forum
Old 04-07-2016, 11:15 PM   #31
Rewards Points: 308
Should I silicone between the bottom of the hardie board and base before I install tile?
bhollehday is offline   Reply With Quote
Old 04-08-2016, 06:46 AM   #32
Retired Moderator
Rewards Points: 7,174
Re: First time Tileing shower - Need tips
Not needed---the flange will direct any water back out of the wall.
Old 04-08-2016, 09:52 AM   #33
Rewards Points: 308
I'm thinking more for moisture though. The whole point is to prevent water and moisture from getting behind the backer board right?
Also do you have any tips for patterning this style of tile? 32x18 18x18 8x18 and 8x8 peices. I found a pattern guide online, but I just want to know if anyone has some tips as I realized it was going to be a lot more difficult than I first thought.
Old 04-08-2016, 08:49 PM   #34
Retired Moderator
Silicone won't hurt--go for it.
That pattern sounds complicated---huge long tiles---you might want to check out leveling clips---Lash by QEP work well and don't cost a lot---
Old 04-14-2016, 10:26 PM   #35
Jello Wrangler
Rewards Points: 539
Originally Posted by Ron6519 View Post
Most instructions say to just rest it on the flange. I think that's stupid as it ignores all water flashing control logic.
I know this is an older post, but how does it ignore water flashing control logic? How much water do you expect to make it paste a layer of caulk, behind the tile, up the flange past another layer of caulk and behind the pan?
And if you are worried about it, just rabbit the bottom of the cement board so that it overlaps the flange a bit.
I am like Mike, I have installed dozens and dozens of tubs and shower pans and never lipped or furred out the durock.
ChiTownPro is offline   Reply With Quote
The Following User Says Thank You to ChiTownPro For This Useful Post:
bhollehday (05-02-2016)
Old 04-14-2016, 10:27 PM   #36
Jello Wrangler
Rewards Points: 539
How would moisture get behind the backer through that gap.
Old 05-02-2016, 03:20 PM   #37
Rewards Points: 308
Thanks for everyone input, mainly of course oh' mike! These are the results of my first tile job. Everything including door, plumbing and base put in for under $1k
First time Tileing shower - Need tips-photo-apr-06-8-09-38-pm.jpg   First time Tileing shower - Need tips-photo-apr-10-8-09-52-pm.jpg   First time Tileing shower - Need tips-photo-apr-16-4-25-12-pm.jpg   First time Tileing shower - Need tips-photo-apr-16-4-25-16-pm.jpg   First time Tileing shower - Need tips-photo-apr-21-1-08-15-am.jpg
The Following User Says Thank You to bhollehday For This Useful Post:
ChiTownPro (05-02-2016)
Old 05-02-2016, 04:55 PM   #38
Jello Wrangler
Rewards Points: 539
You sound like an HGTV show...your time is worth money. Figure in your hours and multiply by what your time is worth and it cost you much more than $1k.
Old 05-02-2016, 05:11 PM   #39
Rewards Points: 308
thanks for making that clear on the do it yourself chatroom. Someone might have assumed I didnt do it myself and drove themselves nuts trying to figure out how it was so cheap!
Old 05-02-2016, 05:37 PM   #40
Retired Moderator
Looking good!
You picked a complicated pattern---congratulations---Mike--
The Following 3 Users Say Thank You to oh'mike For This Useful Post:
bhollehday (05-02-2016), ChiTownPro (05-02-2016), kwikfishron (05-02-2016)
Old 05-02-2016, 06:27 PM   #41
Rewards Points: 308
Originally Posted by oh'mike View Post
Looking good!
One last issue im trying to figure out if i should seal it or not. It seems as though it could go both ways. Im leaning towards not sealing it after doing some reading, but thought I should at least seal the niche and the corner shelves?
What do you think?
Old 05-02-2016, 08:53 PM   #42
Jello Wrangler
Rewards Points: 539
Is it natural stone? If yes, seal it. There is no question.
First time shower pan. Which Method? ubelongoutside Tiling, ceramics, marble 24 05-06-2015 05:55 PM
Re-caulked the tub. It all peeled off by end of shower. Cure time? Bad caulk? Mathlete General DIY Discussions 15 08-04-2014 11:28 AM
Complete bathroom redesign- need help with shower placement Liv Kitchen & Bath Remodeling 0 03-08-2012 12:00 PM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
