Do I Need A Cleavage Membrane? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 04-01-2015, 01:39 PM   #1
Rewards Points: 374
Do I need a cleavage membrane?
I'm installing a 3x4 mortar shower pan in a 2nd floor bathroom.
After much research, I'm leaning towards setting a Laticrete drain in a mortar bed and using Hydro Ban to waterproof everything directly under the tile (i.e. no pre-slope, no vapor barrier).
The Laticrete video says to put a cleavage membrane under the mortar. Do I need to do this on a 2nd floor bathroom, or can I just use some fabric? If I do need it, what should I use?
costgeek is offline   Reply With Quote
Old 04-01-2015, 02:26 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 754
Hi,
Absolutely, yes you need it. And mainly because it's on a suspended wood subfloor. You can't place mud direct on mud or OSB. If you used "some fabric", as you said. That would be the cleavage membrane, right? Use tarpaper, plastic, old plastic sandwich bags etc. Don't forget the lath. Have you considered a shower tray, the kind you can tile over?
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
The Following User Says Thank You to JazMan For This Useful Post:
costgeek (04-02-2015)
Old 04-02-2015, 08:07 AM   #3
Rewards Points: 374
Got it. The video I watched used the term "cleavage membrane" like it was a specific product. I was already planning to put down some kind of construction fabric.
Old 04-02-2015, 09:30 AM   #4
Rewards Points: 144
In the old days we used to call a "cleavage membrane" a bra.Learn something everyday around here.
mako1 is offline   Reply With Quote
Old 04-02-2015, 10:15 AM   #5
Tileguy
JazMan's Avatar
Rewards Points: 754
Well, the word 'cleavage' means a separation, that's what the membrane does. A bra does other things. We just wanna be helpful!
Jaz
Old 04-02-2015, 10:27 AM   #6
Rewards Points: 144
Understand Jaz.Have done my share of tile jobs.Just a bad attempt of making a joke.Got rained out today and am bored.
Old 04-02-2015, 10:30 AM   #7
Rewards Points: 374
Someone HAD to crack a cleavage joke...there's just no way around it.
Old 04-02-2015, 10:32 AM   #8
Tileguy
JazMan's Avatar
Rewards Points: 754
Oh, I know that you know. I just couldn't resist your lead in making the joke.
Jaz
Tags
hydro ban , shower pan , waterproofing
Leaks in membrane roof at posts and edge leakhelp Roofing/Siding 13 09-09-2012 07:22 PM
Shallow pitched roof membrane? SteveB87 Roofing/Siding 6 07-26-2011 09:16 AM
Keraflor for Kerdi membrane myfirstbathroom Tiling, ceramics, marble 9 04-20-2011 01:21 PM
Torch on roof membrane on deck canada55 Roofing/Siding 36 03-03-2011 02:18 PM
roof leak and EPDM membrane dbai Roofing/Siding 8 10-28-2007 05:16 PM
