Concrete Leveling Over Cementboard - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By MK_Chicago
Old 10-16-2016, 07:24 PM   #1
Rewards Points: 52
Concrete Leveling over cementboard
Hi Everyone,
I was pulling up some tile in my entry today (approximately 65 sq ft) and ran into an issue I could use some advice on. The entry is over an unfinished basement. I plan to put in new ceramic tiles.
I used a hammer drill with chisel bit and was able to successfully remove all of the tiles. However, I found that the concrete board underneath is close to an inch thick. There is a metal mesh before the subfloor. Getting up all of the concrete is going to be a big job.
My question is whether I could use a concrete self-leveling product over the existing concrete board in order to get it back to level and then tile directly over the top of that? Most of the 65 square feet came up pretty clean but there are definitely some spots where there are deeper gouges into the concrete (where you can see the metal mesh and inch down.
Has anyone does this before and is it an ok practice or do I just need to get all of the concrete up down to the subfloor?
I attached some pictures.
Mike
Concrete Leveling over cementboard-img_7242.jpg   Concrete Leveling over cementboard-img_7251.jpg   Concrete Leveling over cementboard-img_7238.jpg
MK_Chicago is offline   Reply With Quote
Old 10-16-2016, 08:09 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 768
Re: Concrete Leveling over cementboard
Hi Mike,
First of all, you did not use a hammer drill, it's a chipping hammer aka rotary hammer. Also the concrete base is not concrete board, it's a good old fashion mud job. You've got more than a few spot with deeper gouges, the mud is gone. That base is toast.
You'll either have to replace the mud or you might find it easier the install min. 3/4" ply over the subfloor. Then you'll be able to install your favorite concrete board, then the tiles. Get back when you're down to the subfloor for more advice.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
JazMan is online now   Reply With Quote
Old 10-16-2016, 08:22 PM   #3
Rewards Points: 52
Thanks Jaz for the info. Yes, sorry I meant rotary hammer.
Thanks again
Mike
Old 10-19-2016, 10:18 AM   #4
Rewards Points: 52
To close the loop on this. I ended up ripping it all up. Came up clean but was a big job. However I am glad I did it the right way because it will make for a cleaner install.
jlhaslip likes this.
self leveling concrete chutch76 Flooring 6 04-03-2014 05:41 AM
Drain pipe hole where I want to put self leveling concrete Arsinek Remodeling 5 03-05-2014 11:43 AM
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 12:19 PM
leveling concrete subfloors for engineered wood installation robismyname Flooring 0 10-21-2011 02:01 AM
concrete leveling grainbelt Flooring 5 12-12-2009 09:41 PM
