Ceramic Tile - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 12-09-2010, 12:35 PM   #1
ceramic tile
i have a hole in the concrete slab for a pump and i want to tile the floor,being that i need to be able to access the pump i thought of covering the hole with an aluminum diamond plate and then tile it
my only concern is if it can be done with what to i do it Glue, Thinset, or Mud
yossi is offline   Reply With Quote
Old 12-09-2010, 08:10 PM   #2
A Little Of Everything
Rewards Points: 1,418
I'd tile up to and around the sump hole, and use something else for the lid.
I don't think you'll get Thinset to bond to aluminum. In addition, any flex will ruin your grout and probably break tiles.
DrHicks is offline   Reply With Quote
Concrete floor prep for ceramic tile tpanc13 Flooring 39 06-22-2010 08:50 PM
Water Damaged Ceramic Tile DoubleTrouble Flooring 4 06-12-2010 02:17 PM
Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor mark2741 Flooring 2 11-03-2009 06:08 PM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 06:12 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
