DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Tiling, ceramics, marble (https://www.diychatroom.com/f84/)
-   -   Cementboard and bathtub flange gap issue (https://www.diychatroom.com/f84/cementboard-bathtub-flange-gap-issue-160568/)
n1Patrick 10-19-2012 03:10 PM
I've just put up some hardibacker around my bathtub to 1/8th above the top of the bathtub flange. Now looking at it the is almost a full inch from the bottom of the board to the top of the actual tub edge. I am installing glass pencil tile on the walls. I'm worried that they won't have anything to hold on to in that space. Here are the options I see.
1 - Put mesh tape and thinset (or just thinset) in the 1 inch gap.
2 - Put caulk in the 1 inch gap.
3 - Remove the boards and reinstall boards to 1/4 above tub. This would create a slight bend in the bottom of the boards because the metal studs don't align flush with the front surface of the tub flange (due to flange thickness).
4 - Remove the boards and install furring strips against my metal studs (don't even know if I can do that on metal stubs). Reinstall boards to 1/4 above tub. This would be a lot of work!
So obviously I want to go for option 1 or 2 but am not sure I can put thinset on the flange and I'm not sure caulk will hold well enough in a space that large. Thoughts???
JazMan 10-19-2012 06:58 PM
Hi Patrick,
You know the right answer as well as everyone reading this. You gotta do #4. Or, switch to larger tiles and continue with #1.
You learned a lesson, next time plan ahead better.:thumbsup:
Jaz
n1Patrick 10-22-2012 05:39 PM
I was afraid of this response. I read somewhere that it is Ok to fill the gap with caulk (option 2). But I'm guessing that is not a viable solution.
Can I get furring strips for metal studs? Do they come in different thickness such as 1/4 or 1/2 inch? Sorry for the silly questions but I've never had to do this before.
btw - Forgot to mention the pencil tile will be installed vertically (not sure that makes much of a difference).
joecaption 10-22-2012 06:20 PM
The gap is still far to big, got to lower those panels, no getting around it.
Anything will work as a shim, plywood, OSB, lattis strips. Just use a few fine thread sheetrock screws to attach it.
JazMan 10-22-2012 07:53 PM
Well DAHHHHHH! :laughing: Of course it does Patrick. That was the problem when installed the normal way. You should be able to fill that gap with thinset, and install the tiles vertically. Would I guarantee it? No, cuz any movement might transfer to the tile work and cause grout cracks or worse.
Double check if 1/4" shims will be enough, might not take care of the corners. Lattice is ideal, but anything will work as Joe already mentioned.
Glass pencil tiles as your first project. Huh, should be fun.:eek::no:
Jaz
n1Patrick 10-23-2012 02:09 PM
uh oh, that response worries me.. :icon_confused: I was planning on using my wet saw and maybe some nippers to cut the tile. Any special advice?
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
