Wood Plank Shower Floor - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-24-2015, 09:18 AM   #1
Rewards Points: 16
My wife really wants a spa look for our master bathroom remodel. She is kind of set on a wood floor and zero threshold shower. I have done some custom tile showers before, but never one like this.
A picture of an example of what she wants is below.
I just wanted to bounce my idea off of you guys to see if what I am thinking will work.
If I make a custom pan with a rim around the edges to set my boards on two and a half inches below my current floor with appropriate slope and drain, then have treated lumber cross slats every foot or so, and 1x4 red cedar runners.
I would seal the wood with marine grade stuff and understand that it is a lot higher maintenance than tile, but I told my wife she could design in if it comes out in budget.
Another thought I would have is how I would do the membrane as there is no curb. I have seen a lot of people talk about RedGard membranes that look way to easy and convenient to work well.
Any suggestions or thoughts on my plan would be greatly appreciated.
http://www.trendsfloor.com/wp-conten...r-65vts9t7.gif
carter72 is offline   Reply With Quote
Old 04-24-2015, 10:38 AM   #2
Rewards Points: 17,890
I'd be making it out of Teak and sealing with Teak oil.
de-nagorg (04-24-2015)
Old 04-26-2015, 01:03 PM   #3
Rewards Points: 16
My wife really loves cedar. Is the process I explained correct?
Old 04-26-2015, 02:10 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 606
Seems the pit you are building below the cedar will become a mildew / mold farm. You need a way to ventilate and dry it out.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 04-26-2015, 02:39 PM   #5
Property Mgt/Maint
Rewards Points: 6,378
I think a wood floor shower in a outdoor pool house exposed to sun, and air movement is a cool idea. As part of the master bath being used daily, I'm not as convinced. Have you considered some of new wood grain ceramic tile?
[political signature removed]
Yodaman is offline   Reply With Quote
Old 04-26-2015, 05:35 PM   #6
Retired Moderator
Rewards Points: 7,174
Is your shower being built over a slab or conventional framing?
If framed,is it over a basement or a finished first floor room?
Old 04-26-2015, 06:18 PM   #7
Rewards Points: 16
I cannot belive I forgot about location. On a slab that I have to move all the plumbing in. Going to be a pain, but as I will already have a Concrete saw out so I will have plenty of space to drop the pan
Old 04-26-2015, 06:34 PM   #8
Retired Moderator
That makes it easier---I recommend Hydroban by Latactete as a waterproofing--
You could use their drain set or use the 'divot' method and use a standard clamp drain.
You will still need to protect the paint on membrane with tile--it is not intended as a wear surface.
Old 04-26-2015, 06:35 PM   #9
Retired Moderator
Go to Latacrete web site--lots of videos
Old 04-26-2015, 06:39 PM   #10
Rewards Points: 16
So, I would have to tile the floor under the boards? A sloped concrete wouldn't be enough?
Old 04-26-2015, 06:52 PM   #11
Retired Moderator
Concrete is not waterproof and will soak up water and soap--the surface needs waterproofing---and the waterproofing needs abrasion protection.
Sorry to bare the bad news---
Old 04-26-2015, 06:57 PM   #12
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,054
Mike .... is liticrete a paint on "redguard" product or more a "kerdi" membrane...... any reason you prefer it.
TIA.... (always learning)
MTN REMODEL LLC is offline   Reply With Quote
Old 04-26-2015, 07:02 PM   #13
Retired Moderator
Yes, Hydroban is a paint on waterproofing---it is intended for use on shower pans--long respected product--leaves a nice heavy layer.
I've used it on pans---and walls---never had an issue.
I do use Redguard on walls---never completely trusted it for floors--it might be approved for that use--I tend to stick with what I know has worked in the past.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Replacing Garden Tub w/Tile Shower on a Slab floor.. Need Help!! cufflinks General DIY Discussions 16 05-20-2013 06:16 AM
Where should wood floor stop and carpets begin. rickjames8 Flooring 5 05-08-2013 09:02 AM
creating new shower floor/ slope??? Bob Funk Plumbing 2 03-01-2010 04:22 PM
Shower floor leaking...help! slloyd Plumbing 5 06-13-2009 01:34 PM
