Wiring A Ceiling Vent - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By chandler48
Old 12-06-2017, 03:33 PM   #1
Rewards Points: 66
wiring a ceiling vent
Trying to wire a vent/heater/light using the attached diagram. when i turn on breaker switch it trips. i had this all wired before i put it in with no issues and i canít figure out why it would be tripping. any suggestions? thanks
owenpga is offline   Reply With Quote
Old 12-06-2017, 04:09 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,624
Re: wiring a ceiling vent
USUALLY, the black goes to the fan, the red to the heater and the blue to the light. Do you know which cable controls which function? Does the 12-3 control the light and fan, or the fan and the heater? Did you mess with the switch wiring? Seeing a picture of the switch pulled from the box would help, also.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
owenpga (12-06-2017)
Old 12-06-2017, 04:24 PM   #3
Rewards Points: 66
. forgot to attach this diagram. you are correct with which color goes with what function.
Sorry for my ignorance but is the 12-3 the one with 3 wires? if it is, that wire coming from box is only for the light. the 4 wire cable connects to the wires for heat and vent. I havenít messed with switch as it was working earlier. you can see from the diagram how itís wired. it was a pain in ars getting the switch back in , so iím reluctant to pull it out again. thanks
Old 12-06-2017, 04:35 PM   #4
Naildriver
chandler48's Avatar
OK, the black from the 12-2 (two wires and a ground) will connect to the black of the unit. The black from the 12-3 will connect to the fan, and the red to the heater. Make sure your neutrals are connected to the correct white incoming cable. Light to light and fan/heat to the 12-3 neutral. Make sure none of your grounding wires are folded in a way to where they can contact any other wire and make sure your wire nuts cover all the exposed wires for hots and neutrals.
Larry......
Old 12-06-2017, 05:10 PM   #5
Rewards Points: 66
so in your first connection, black to black of unit. iím assuming you mean black of 12-2 to the blue wire from light . is your explanation any different than the diagram. Iím not seeing any difference? is my drawing correct . thank you
Old 12-06-2017, 05:16 PM   #6
Naildriver
chandler48's Avatar
Yes, I may have mis stated it. Your drawing looks to be in order.
owenpga likes this.
Larry......
Old 12-06-2017, 05:29 PM   #7
Rewards Points: 66
we are in business. all switches work. thank you so much for your time.
Old 12-06-2017, 07:01 PM   #8
Naildriver
chandler48's Avatar
Glad to help.
Larry......
Old 12-17-2017, 07:22 AM   #9
Rewards Points: 66
So I just received my insulated duct for the the 3 way ceiling unit and was told by the roofer who installed
my roof vent that i should have 18Ē of insulation in the attic or in
my case the dormer. I have nothing close to that. I basically had to cut an opening next to unit in order to get my body into space above bathroom since i have no attic access. So my question is two fold:
1. should i lay down more insulation? Will it make that much of a difference in room temp?
2. how much room around unit, which has a heater do i need for safety reasons?
thanks
owen
Wiring a ceiling fan, light on a switch, fan always hot philnotfil Electrical 9 11-02-2014 10:00 AM
Ceiling fan wiring mess mitchell1297 Electrical 2 05-16-2014 05:26 PM
Help with wiring Ceiling fan to dimmer to light fixture. how was it wired? RedDirtdog Electrical 3 04-22-2014 12:05 AM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 06:29 AM
