Window Not For Residential Use - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 1 Post By joecaption
  • 1 Post By de-nagorg
  • 2 Post By CEBHMB
  • 1 Post By badams
Old 10-27-2016, 04:42 PM   #1
Rewards Points: 20
Question
Window not for residential use
My contractor has installed a window in my bathroom that is labeled by the manufacturer (JELD-WEN) as " not intended for use in residential structures" because the window has not received a design pressure (DP) rating. I have asked him to install a different window and he is delaying. Should I hold out for a different window?
CEBHMB is offline   Reply With Quote
Old 10-27-2016, 09:57 PM   #2
JUSTA MEMBER
Rewards Points: 3,538
Re: Window not for residential use
Yes.
Do not make the final payment until you are happy.
This window will probably affect your home insurance policy.
ED
de-nagorg is offline   Reply With Quote
Old 10-27-2016, 11:16 PM   #3
Rewards Points: 1,514
Yes. That's ridiculous. Don't pay. I'd also take a very close look at the rest of his work... Did he pull a permit for the work he is doing? Not sure on the scope of this project.
ryansdiydad is offline   Reply With Quote
Old 10-28-2016, 09:19 AM   #4
Rewards Points: 17,884
Contacted Jeld-Wen yet and asked them any questions about what that all means?
MTN REMODEL LLC likes this.
Old 10-28-2016, 04:45 PM   #5
Rewards Points: 20
I haven't contacted the Manufacturer but the contractor says he has and they claim not to make a window with no DP Rating- but I have the sticker that came off the window. Thanks for all the good input. We'll see how this works itself out.
Old 10-28-2016, 09:26 PM   #6
JUSTA MEMBER
I would still contact JELD-WEN myself, with the model # and sticker # just to verify the story.
ED
123pugsy likes this.
Old 10-29-2016, 05:35 AM   #7
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,264
ED
http://en.jeld-wen.ca/jeld-wen/contact_us/
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
The Following User Says Thank You to 123pugsy For This Useful Post:
de-nagorg (10-29-2016)
Old 10-29-2016, 02:40 PM   #8
Rewards Points: 20
You're right and I'll do that. Its the only way to be sure......Thanks
123pugsy and de-nagorg like this.
Old 12-01-2016, 08:40 PM   #9
Rewards Points: 76
I'm left being curious here....
Is this the same contractor that did your shower pan?
ryansdiydad likes this.
badams is offline   Reply With Quote
Old 12-02-2016, 12:19 PM   #10
Rewards Points: 20
Same guy. He said he went to 7 different stores to find a window and the one he settled on couldn't be used in residential homes. I think he's grown his business too fast and doesn't pay attention to "details"- just looks for a deal on the things he buys.
Old 12-02-2016, 08:31 PM   #11
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,020
You are right to be concerned.... and need a clear/clean answer.....
but I'm guessing that there is some environmental test that they have not completed and stuck the appropriate disclosure on the window.... I'm not sure why it would refer to residential use, but environmental codes are sometimes pretty flaky....
(i would think it would be precluded from commercial use before it was precluded from commercial use... but then again, we don't require seat belts on school buses... it would cost too much...?????)
MTN REMODEL LLC is offline   Reply With Quote
Old 12-02-2016, 09:28 PM   #12
Rewards Points: 20
The sticker said that the window wasn't "DP" (pressure) rated and could only be used in outbuildings.
Old 12-02-2016, 09:41 PM   #13
CB....
I have no idea... but sure interested in what you find out.... why an outbuilding would be an exonerating factor from a non-outbuilding.
DP.... My only guess would be "differential pressure" but that makes no sense. (Did they forget a breather tube...???)
And I sorta doubt a main line manufacturer makes windows designed for outbuildings only.... I think we got some environmentalists/state laws/ and Philidelphia attorneys involved here.
Good luck friend... let us/me know for our education.
Best
Old 12-03-2016, 07:41 AM   #14
Is the window still installed at ur house? You didn't make him remove and replace? I've never dealt with a contractor that goes to 7 stores to buy a window. They have all ordered them direct from the manufacturer reps.
Did this guy buy some floor sample or something?
Besides this and the shower pan what else did this guy do?
Old 12-04-2016, 08:42 AM   #15
Rewards Points: 2,438
Googled dp and it came up design pressure. Meaning pressures of wind and snow. Means you have cheapest window and probably leaky and depends on what you were promised and what you wanted. If you said cheapest, you got what you wanted. Windows can be made tighter with weather stripping. I'd pay half, fire the contractor and begin all over again.
Outhouse means storage. No heating or insulating.
BTW, most residential vinyl windows are leaky. What kind is it? Even double hung can be weather stripped and bathrooms are usually warmest. It can stand a little leaky.
carpdad is offline   Reply With Quote
Tags
dp window rating
General window install questions miamicuse Windows and Doors 9 04-23-2013 08:05 PM
how to deal with a window in a shower MLMIB Kitchen & Bath Remodeling 9 09-12-2012 08:41 AM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
