What Wall Cabinet Height To Choose? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 09-23-2014, 11:52 AM   #1
DIY-Her's Avatar
Rewards Points: 295
what wall cabinet height to choose?
We have 9ft ceilings on the 1st floor.
The kitchen currently has 42" wall cabinets.
We are replacing the wall cabinets, and at least 2 of them I want to replace with cabinets that go to the ceiling after the 3 5/8" crown is installed.
My question is, I know 3 5/8" isn't the exact height of the crown
(we haven't actually purchased it yet)
Sp what height to I request those 2 wall cabinets so there is enough room to install 3 5/8" crown?
The wall cabinet above the range will be at least 15" deep where the other wall cabinets will be 12 1/2" deep.
Here is a photo of the kitchen where I replicated the cabinet above the range to make it look taller like we plan to order.
DIY-Her is offline   Reply With Quote
Old 09-23-2014, 12:35 PM   #2
Rewards Points: 144
You do know that 3 5/8" crown on the flat is not going to be 3 5/8" vertically when installed?Best bet is to pick the crown before the cabinets and get an exact measurement as it will be installed.
mako1 is offline   Reply With Quote
Old 09-23-2014, 04:05 PM   #3
DIY-Her's Avatar
Rewards Points: 295
yes, I realized that which was why I was asking. Didn't know if there was a mathematical way to know what the crown height would actually be installed.
I'm thinking 3 5/8" would be the maximum crown size I should go with my cabinets. I know there was a 5 and something crown and even larger, but too big for our kitchen.
Old 09-23-2014, 04:12 PM   #4
Rewards Points: 144
The angles on the bottom and top of crown do vary.That's why you need to pick the crown first.There are different spring angles.If you knew what crown you were using there are formulas to figure this out but since they vary you don't know the angle of the crown which makes these formulas worthless.
Old 09-23-2014, 04:14 PM   #5
Rewards Points: 144
https://www.google.com/search?q=spri...w&ved=0CB0QsAQ
See my point?
The Following User Says Thank You to mako1 For This Useful Post:
DIY-Her (09-23-2014)
Old 09-24-2014, 09:19 AM   #6
Rewards Points: 29
I would do a stacked crown that adds up to about 6". With stacked crown, usually there is one piece that goes up vertically, and then your regular crown attaches to that. The big benefit to doing it this way is that ceilings are not usually level, and trying to install crown on top of the cabinets and touch the ceiling can leave gaps. Having 2 pieces with a vertical section allows some float room and will hide any unlevel areas.
cube17576 is offline   Reply With Quote
The Following User Says Thank You to cube17576 For This Useful Post:
DIY-Her (09-24-2014)
Old 09-24-2014, 11:26 AM   #7
DIY-Her's Avatar
Rewards Points: 295
If I went with stacked crown, do I have to do that on say the 42" high that won't go to the ceiling, as well as the 2 I want to go to the ceiling? Here is one I found on Facebook from a local trim installer that we may have install our wall cabinets.
Here is a photo of a local kitchen he had done in the past.
Don't know the height of that kitchen, nor the cabinet height, but the layout is similar except the cabinet to the right of the smaller high cabinet is 27" wide and I also want to do my corner susan wall cabinet to the ceiling.
Old 09-25-2014, 08:07 AM   #8
Rewards Points: 2,490
Because of shorter family, I put the upper cabinet at 16" for easier reach (from finished counter top). It gets crowded with that mixer with motor that pivots up and down?
What is recommended is 18". Some adjustments are possible, so from there, it's up to what you want.
carpdad is offline   Reply With Quote
Old 09-25-2014, 10:54 AM   #9
DIY-Her's Avatar
Rewards Points: 295
I think it's a township code that kitchen cabinets have to be 18". We aren't really short so to speak, although I'm 5'4" husband is 6'3" We have 2 small appliances, the coffee maker and the Brevel toaster oven that have to fit under our counters.
I was actually thinking to raise it 18.5" or even 19" since we are putting a light rail under the cabinet that will lower the height a bit.
Old 09-25-2014, 01:20 PM   #10
Rewards Points: 105
When our upper cabinets were installed we had one area we installed at 17" to accommodate a microwave shelf. And I sure do wish it was 18". I moved the dish drain to the other side of the sink where it is 18" for the extra height. Who would have thought 1" would make that much difference in functionality. YMMV 😀
MaineLL is offline   Reply With Quote
The Following User Says Thank You to MaineLL For This Useful Post:
DIY-Her (09-25-2014)
Old 09-25-2014, 02:31 PM   #11
DIY-Her's Avatar
Rewards Points: 295
good point MaineLL For us at least, our microwave isn't on a shelf, but over the range. Wondering if raising that cabinet even 1 inch who help or hurt.
Cabinet too shallow for wall oven? knute General DIY Discussions 16 08-17-2017 10:24 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Retaining wall first step height techdogg Landscaping & Lawn Care 4 08-07-2014 06:11 PM
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 03:43 PM
code for determining retaining wall height mrdol General DIY Discussions 2 11-08-2007 02:47 PM
