What To Use For Wall In Shower? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-31-2012, 08:19 PM   #1
Rewards Points: 357
What to use for wall in shower?
We are in the middle of our bathroom remodel and are adding a walkin shower that will have 3 walls of glass and one side is the actual wall in the bathroom. That wall will be tiled, but what needs to be used to cover the wall studs?
We put up the mold proof type sheetrock stuff, but I am thinking that in the shower needs to be something else...something more waterproof?
bassadict69 is offline   Reply With Quote
Old 05-31-2012, 08:48 PM   #2
Rewards Points: 17,884
No form of drywall should be used in a wet area.
Use 1/2" Tile board instead.
It gets attached directly to the studs with tile board screws. Once it's up it needs to be waterproofed. Look into a product called Red guard.
As the tiles go up all the seams need to be sealed with webed tile board tape and set in place with thin set.
Never use mastic in a wet area!
bassadict69 (06-02-2012)
Old 05-31-2012, 08:51 PM   #3
http://www.ehow.com/about_5660063_tile-board_.html
Old 05-31-2012, 08:59 PM   #4
Retired Moderator
Rewards Points: 7,174
Durrock or one of the other cement boards is the simplest way---waterproof the surface with Redguard or Hydroban---or go top drawer and waterproof with Kerdi by Schluter--
Old 06-02-2012, 06:50 AM   #5
Rewards Points: 357
Awesome info...Thanks!
The Following User Says Thank You to bassadict69 For This Useful Post:
oh'mike (06-02-2012)
Complete bathroom redesign- need help with shower placement Liv Kitchen & Bath Remodeling 0 03-08-2012 12:00 PM
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 08:03 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
