What Type Of Material For Shaker Style Cabinet Doors Only - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-24-2018, 03:05 PM   #1
Rewards Points: 254
What type of material for Shaker style cabinet doors only
Looking to construct new doors for my current cabinets, not sure what original material is, but looks like there is some type of veneer on top. Eventually everything will be painted espresso. So no need to worry about grain/etc.
Looking to do this on a budget so won't be able to afford really expensive wood, looking for a middle ground material that isn't too soft but won't break the budget. Would it be acceptable to use poplar for styles and rails and then pine for plywood panel? Or would MDF panel be fine in this case?
Thanks!
mbrando1994 is offline   Reply With Quote
Old 02-25-2018, 04:35 AM   #2
retired painter
Rewards Points: 1,430
Re: What type of material for Shaker style cabinet doors only
Do you intend to prime and paint the doors or just finish them with a dark stain and poly?
mark sr is offline   Reply With Quote
Old 02-25-2018, 09:32 AM   #3
Rewards Points: 944
Poplar would be fine for the frame. A little soft, maple is what is typically used for painted cabinets, but poplar would be OK. I'd use mdf for the panel. I think pine plywood is hard to paint.
Marson is offline   Reply With Quote
Old 02-25-2018, 04:42 PM   #4
Rewards Points: 334
https://www.cabinetdoorworld.com/mdf-shaker-door/
Mdf $12/sq.ft.
Tymbo is offline   Reply With Quote
Old 03-04-2018, 12:15 AM   #5
Rewards Points: 30
Building a good door can be tricky, but doable DIY with proper equipment, patience, and approach.
Poplar and maple are excellent choices for painted cabinets. Maple is stonger and a better material overall. For good reason, it is the most common species choice for painted cabinetry.
MDF is fine for the panels.
If you are doing recessed panels, I would suggest 1/2” MDF with a rabbet cut into the back side of the panel, rather than 1/4” material. It will yield a heavier, robust door with a solid feel. Use 3/4” MDF for raises panels with a chamfered edge.
A high quality 1/2” plywood, such as birch, could also be used for a recessed panel. Pine would be a sacrifice and unless it’s a cabinet grade A faced, it may need some grain filler to smooth the surface.
NEPA Remodeling is offline   Reply With Quote
Tags
cabinet , doors , shaker
Painting cabinet doors jmiza Painting 3 12-28-2012 04:36 PM
Veneering old cabinet doors sillycat41 Kitchen & Bath Remodeling 2 06-10-2012 10:23 AM
Kitchen cabinet doors jad Kitchen & Bath Remodeling 2 04-13-2010 08:35 AM
Correct Material for Eye-level Oven Cabinet Bouraq Carpentry 4 02-05-2009 05:13 PM
