What Should Be Under Tub? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-16-2011, 09:38 PM   #1
What should be under tub?
Hello,
Gutting the bathroom, I discovered that the tub sits on just the plywood subfloor and there has definitely been rodents under there. The floor looks to be in good shape and the tub has no leaking issues. Should I put anything under or around the tub? I've heard people suggesting spray foam on the tub?
enigmaingr is offline   Reply With Quote
Old 08-17-2011, 06:35 AM   #2
Retired Moderator
Rewards Points: 7,174
No spray foam----cast iron and steel tubs simply sit on the floor with steel shims if needed.
Some fiberglass tubs are set into a bed of masons mortar to prevent flexing.
Old 08-17-2011, 06:50 AM   #3
the Musigician
DangerMouse's Avatar
And mice love to tunnel through spray foam. It makes perfect housing for them.
DM
Old 08-17-2011, 08:04 AM   #4
Retired Moderator
It is nice and warm---kind of like a well built mouse apartment---
enigmaingr (08-17-2011)
Old 08-17-2011, 10:01 AM   #5
Thanks for the replies. So should the floor under the tub have anything special on it or just leave bare subfloor?
Old 08-19-2011, 07:55 AM   #6
Retired Moderator
Plain subfloor is the usual way.
