What Gets Installed First, Door Jams Or Tile? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By joecaption
Old 01-14-2017, 02:06 PM   #1
Rewards Points: 396
what gets installed first, door jams or tile?
I'm getting ready to drywall and after that I can install the pre-hung doors or I can wait to install them after the tile.
Option 1) - Doors first
advantage - easier I think, don't need to trim bottom of the jam on the pre-hung door to avoid massive gap between door and floor.
Option 2) - Tile first
advantage - don't have grout line between tile and jam
Is there a "correct" way or way that is more common? I'm thinking option 1 but wanted to make sure I wasn't overlooking anything.
Thanks!
MLMIB is offline   Reply With Quote
Old 01-14-2017, 03:49 PM   #2
Framing Contractor
Rewards Points: 50
Re: what gets installed first, door jams or tile?
Thanks!
I prefer number 2, but you can do it either way.
sixeightten is offline   Reply With Quote
Old 01-14-2017, 04:48 PM   #3
Rewards Points: 17,890
Tile what? The floor, wall?
Grout should never be used between the jam and tile!
Any time tile changes direction or meets a dissimilar material you use caulking not grout.
jlhaslip and Dave Sal like this.
Old 01-14-2017, 08:16 PM   #4
jlhaslip's Avatar
Rewards Points: 708
I would tile first so the Jamb can rest directly on the tile floor.
Be prepared to cut one side of the Jamb to level in the head Jamb as required.
Caulk the jamb to the floor.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
How to remove ceramic tile that was installed over marble hex tile? bam42 Tiling, ceramics, marble 1 01-15-2013 11:59 AM
Tile over Painted Lightweight Cement New_2_DIY Flooring 16 08-28-2011 02:29 AM
Can Partial Drain Tile be Installed? butchbs1985 Plumbing 3 07-26-2011 07:11 AM
remove one row of newly installed tile? Taran7 Tiling, ceramics, marble 3 07-10-2011 08:15 PM
Window installed over tile / new tile bobzemuda Building & Construction 1 12-01-2010 11:31 AM
