DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Kitchen & Bath Remodeling (https://www.diychatroom.com/f80/)
-   -   What gasket material to use to hold glass to medicine cabinet door? (https://www.diychatroom.com/f80/what-gasket-material-use-hold-glass-medicine-cabinet-door-189131/)
Rav 10-23-2013 04:41 PM
1 Attachment(s)
I'm having the mirror from a 1931 bathroom medicine cabinet re-silvered. The mirror (glass) is held on with brackets that screw into the top and sides (not bottom, interestingly) of the cabinet. They hold the glass on by friction clamping. The brackets were lined with some sort of soft flexible gasket material, so that when the screw is tightened, the gaskets swell to grip the glass onto the door. The gasket fits in the "cup" of the bracket. I've included a picture of a bracket below. The issue is that the original gasket material was disintegrated to the point of being unusable. Can anyone suggest a specific gasket-type material that would work for this? Thank you.
gregzoll 10-23-2013 05:19 PM
Go back to the local glass shop that you had re-silver the mirror, and they will have the Silicone squares that are used.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
