What To Do With Cement Board To Drywall Seam? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-23-2014, 08:01 PM   #1
Rewards Points: 150
What to do with cement board to drywall seam?
So Im working on my second bathroom project. I've got my cement board and drywall up but the gap on one of the walls where the to materials come to together looks pretty rough.
Does the drywall need to be fixed up more before I tape the seam and mortar it or could I go ahead and do it now?
Arsinek is offline   Reply With Quote
Old 04-23-2014, 08:12 PM   #2
Rob
Robpo's Avatar
Rewards Points: 826
I would tape it now using thinset and spackle it after the tile is grouted.
Robpo is offline   Reply With Quote
The Following User Says Thank You to Robpo For This Useful Post:
garlicbreath (04-23-2014)
Old 04-23-2014, 10:56 PM   #3
Rewards Points: 29
I would use drywall compound, using thinset will make that seam very difficult to hide unless you're tiling over it.
liljohnny is offline   Reply With Quote
Old 04-24-2014, 12:14 AM   #4
Rewards Points: 744
Drywall mud, when joining cement board to drywall. I would opt for setting-type drywall compound, in an area that could possibly see direct moisture. The setting-type compound will also fill in those larger gaps better than regular mud. Top coat with regular drywall mud, if necessary, on the areas that won't be under tile. Also, it looks like some of the paper facing has been removed on the edge of that drywall. I would put some more screws in, where there is paper.
Seattle2k is offline   Reply With Quote
Old 04-24-2014, 07:31 AM   #5
Rob
Robpo's Avatar
Rewards Points: 826
Didn't think of that. I have used the Durabond Dual 90 and it is tough stuff. My thought was while grouting the regular drywall mud would get scratched.
Old 04-24-2014, 07:53 AM   #6
Rewards Points: 150
Well this whole area might be covered with tile. If so could I just use mortar?
Sent from my Nexus 5 using Tapatalk
Old 04-24-2014, 08:16 AM   #7
Rob
Robpo's Avatar
Rewards Points: 826
If you can get it smooth enough to put the tile you are using over it. But I would still tape it . I am guessing you are working on it now because it looks like you are using your phone to post (Sent from my Nexus 5 using Tapatalk). Not knowing all the facts it is hard to give you a good answer.
Old 04-24-2014, 08:31 AM   #8
Rewards Points: 150
No. I'm at work. They have this site blocked on our PCs for some reason.
Old 04-24-2014, 09:21 AM   #9
Rob
Robpo's Avatar
Rewards Points: 826
The more info about the project the better some one can help you. The pics are great but type of mortar and tile, size, thinset it is frustrating giving some one advise and then finding out that they are using a different application. Its like going to the auto parts store and asking for a spark plug. They want to know make, model, year,engine. Sorry for rambling on but I gotta go.
Old 04-24-2014, 10:49 AM   #10
Rewards Points: 150
6 inch ceramic tile, mapai thin set, don't remember the exact kind.
Old 04-24-2014, 03:09 PM   #11
If it were me I would actually cut out and replace that section of sheetrock to get a better edge. And if it were me I would tape the seams with fabric tape or FG matte and then apply waterproofing membrane to the entire shower walls overlapping onto the sheetrock. And I would have my tile layout spill over to the sheetrock so that the seam would be completely covered.
DIYRemodeler is offline   Reply With Quote
Drywall or cement board on floor first? Daugela Drywall & Plaster 5 07-10-2013 02:00 PM
Uneven cement board shower/tub surround SlimCharles Concrete, Stone & Masonry 2 09-26-2012 01:01 AM
Cement board over drywall Spacebear3 Drywall & Plaster 1 08-29-2011 06:49 PM
Assistance with tile layout / transition between cement board and drywall JeffreyMCooper Tiling, ceramics, marble 4 08-20-2011 11:47 AM
drywall compared to cement board on garage ceiling Goob Drywall & Plaster 4 04-05-2011 03:57 PM
