What Is This, Cut-outs Behind Trim - Kitchen & Bath Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-25-2015, 05:06 AM   #16
Rewards Points: 107
Wire fishimg, inspection hole etc. and some one was to lazy to fix it up. Other than general incompetence and laziness of the prior owner there is nothing to report here. Patch it and be on your way. Defects in your home are just something that need to be fixed. Unless you just bought the house and the prior owner failed to disclose significant defects or the owner and or realtor tried to cover a defect you have little recourse. This is not significant and easily repairable. The prior owner could easily claim no knowledge (like. "How would I know, I never took the baseboard off)" ) . There is no proof otherwise and it's not big enough to fight over. If he covered up a leaking roof, that is different story.
jimn01 is offline   Reply With Quote
The Following User Says Thank You to jimn01 For This Useful Post:
oh'mike (02-25-2015)
Old 02-26-2015, 10:17 AM   #17
USMC
Rewards Points: 42
Thanks. Not worried about fixing it just determining how far to go. I want to avoid making a irreversible mistake, wasting time.
Fordstanger is offline   Reply With Quote
Old 02-26-2015, 06:15 PM   #18
Retired Moderator
Rewards Points: 7,174
Fairly simple repair---add a bit of 1x2 blocking at the top---and screw in a piece of drywall--then tape ,fill and sand---most will be hidden by your new trim--so only the top portion of your patch need to look nice-------
Old 02-26-2015, 07:06 PM   #19
USMC
Rewards Points: 42
Yep, may go half wall in tile which will require backer board anyway.
The Following User Says Thank You to Fordstanger For This Useful Post:
oh'mike (02-27-2015)
Removing latex paint from wood trim ulbass Painting 8 09-13-2017 05:46 AM
Question about hardiepanel/T-111 and window trim Alan Roofing/Siding 4 08-22-2014 09:06 PM
How To Seal Tyvek Terminations At Wood And Composite Trim? gunner666 Roofing/Siding 5 08-06-2014 01:52 AM
Old Flooring and Trim Identification and Refinishing BungalowBaby Flooring 8 07-02-2011 06:17 PM
Replacing all doors and trim...lots of questions... Badfish740 Carpentry 5 07-27-2008 12:16 PM
