What Caulk/sealant To Use On Wood-to-wood Joint That SLC Can Be Poured Over?? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-05-2016, 06:37 PM   #1
Rewards Points: 14
What caulk/sealant to use on wood-to-wood joint that SLC can be poured over??
Hello.
I'm going to lay Self Leveling Concrete over my bathroom floor but have this small area in front of the door that was not concrete but wood. I replaced the existing wood with a fresh piece of 5/8" plywood and now need to seal around this piece of wood. My question is, what product do I use to seal around this piece of wood so that I can then coat over it with a floor primer and then finally the self-leveling concrete??
See photo attached please. (Note: the piece of wood shown in front of the door is surrounded by 2x4s, used as the template when pouring the concrete originally, so it's a wood-to-wood joint that is in question)
ChuckHammer is offline   Reply With Quote
Old 03-05-2016, 08:02 PM   #2
Rewards Points: 1,346
Pull the wood, put in cement backer board instead, cover it with whatever. Ron
ront02769 is offline   Reply With Quote
Old 03-06-2016, 12:28 AM   #3
Rewards Points: 14
Thanks Ron. Good idea.
Need help identifying stained pallet wood. (pics) zpafk6 Carpentry 9 02-16-2016 08:41 PM
Pressure treated lumber inside dimples4christ Carpentry 32 12-25-2014 08:59 AM
exterior wood paint chips & craters. Can I fill it in with joint compound? pman6 Painting 9 09-22-2013 03:46 PM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 03:14 PM
