Wet Bar Layout Help - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-29-2014, 02:41 PM   #1
Rewards Points: 117
Man Cave Wet Bar Layout Help
So I made these 5 possible layouts for my 4' wide wet bar. Need some help picking a layout.
Some notes:
Top of counter to bottom of the tallest cabinet is 19".
The 2' 9'' is the height of the frig.
Floor to top of counter is 36".
There is a wall on both side of the wet bar. (see pic below)
tommyxv is offline   Reply With Quote
Old 03-29-2014, 02:58 PM   #2
Rewards Points: 298
arc in the uppers is a dated look
JustinK is offline   Reply With Quote
Old 03-29-2014, 03:08 PM   #3
Rewards Points: 117
Originally Posted by JustinK View Post
4
Thanks for the feedback. I like your layout pick. It was 1 of the 2 I was leaning towards.
Here is a pic of the actual doors I was planning to use.
This one is an option as well...
Old 03-29-2014, 03:20 PM   #4
Rewards Points: 298
That arch is better. The taller upper is showing an exaggerated arc in drawing is what through me off. Personally I would go without arch thought. What about a glass insert?
Old 03-29-2014, 03:22 PM   #5
Rewards Points: 298
The smaller arc with glass would look good. Since it is a bar it will probably be glasses in there.
Old 03-29-2014, 03:30 PM   #6
Rewards Points: 117
The program I used to make the layouts messed up the arcs a bit. The local place that I am getting them from only offer glass insert doors on 15"w + cabinets. The total for all the cabinets is $330. These are RTA cabinets for the man cave wet bar.
Some of the cabinet specs...
  • Doors and face frames are made from solid Maple
  • Solid plywood cabinet box
  • No Particle Board is used anywhere in their construction
  • Raised panel doors with four molded sides
  • Sunset Maple finish
  • Euro Epoxy drawer slides
  • Concealed European hinges
  • Drawer boxes with 1/2" all wood sides and back stained to match the color of the cabinets
Old 03-29-2014, 03:35 PM   #7
Rewards Points: 298
Thats an awesome price.
Old 03-29-2014, 03:42 PM   #8
Rewards Points: 117
For where they are going and how often they will be used, I am happy with the quality and price.
Old 03-29-2014, 06:26 PM   #9
Rewards Points: 117
Updated and added a V6 layout. It's similar to V4. What do you think?
Kitchen/Dining Room Layout JRDepew Remodeling 2 01-23-2014 12:04 PM
Assessing value of layout changes mbianco General DIY Discussions 6 07-21-2012 11:48 PM
Bathroom DWV Layout Problems grymes56 Plumbing 8 05-15-2011 09:00 AM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
