Which Waterproofing System For Shower? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 12-10-2011, 10:18 AM   #1
In a little over my head
Rewards Points: 710
which waterproofing system for shower?
Plumbing for my new bathroom is almost done. Insulating should go quickly. So, I'm on to thinking about the tile. The shower is 3x4', no tub; tile will probably go to the ceiling. I'll be making a mud bed. What waterproofing system do you guys recommend for a novice? I'd planned on Kerdi, after reading John Bridge's forum. Now I'm not so sure. Our local tile supplier sells Hydroment and Gold Plus. I've heard of RedGard, too.
I've tiled a couple rooms, but never a bathroom. Which system is the best bet for a novice?
Thanks!
ratherbefishing is offline   Reply With Quote
Old 12-10-2011, 10:22 AM   #2
Retired Moderator
Rewards Points: 7,174
Are you hand building the shower pan?
Are you using A cement backer on the wall?
Waterproofing what exactly?
Shower pan--walls?
Old 12-10-2011, 11:00 AM   #3
Rewards Points: 710
Yup. Handbuilding the pan. 1/2" cement board on the walls.What do you like between the floor/walls/curb and the tile?
Old 12-10-2011, 11:03 AM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Explain that comment will ya?
Old 12-10-2011, 11:13 AM   #5
Rewards Points: 710
Too much reading, I guess. The folks over at JB really like Kerdi. I can get it at Home Depot. But some at Terry Love's forum don't. Redgard has been mentioned. The local tile store recommends Gold Plus, a roll on membrane. So, now I'm confused.
All that's done now is the framing (dried in) and plumbing rough-in. No drain hole in the shower floor yet. In fact, the shower is just a chalk line on the floor.
Old 12-10-2011, 11:23 AM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Okay let's try to clear this up. The KERDI recommendation is the only way to go in your case simply because you don't know what you are doing and the KERDI system is very user/DIY friendly.
The folks at Terry Love's are all sweethearts I'm sure but they are plumbers first and tileguys last. And I mean last. So forget about the Love website when it comes to tile stuff.
Now if you have already been to JB's website then you already have all the information you need to do your proper installation and you won't get anything very different here.
If you continue to visit every website you can find on the subject you will stay confused and you won't get anything accomplished.
By-the-way...The liquid membranes are no substitute for the KERDI or the NOBLE systems and wouldn't be recommended for your shower pan liner if that's what you are thinking.
Pick a website and stay with it.
Pick a shower system and stay with it.
Get a plan and stay with it.
Old 12-10-2011, 11:32 AM   #7
Rewards Points: 710
Bud,
I've read that Kerdi does not allow the use of "modified thinset". Is that a problem?
Old 12-10-2011, 11:37 AM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The type of thinset used for KERDI depends on what the KERDI is being applied to. There's a real long story about all that nonsense that goes back years but I'm not spending any time on that right now.
Why are you asking? What's up?
Old 12-10-2011, 03:03 PM   #9
Rewards Points: 710
Nothin's up. I'm just trying to be well prepared, before I start.
Old 12-25-2011, 12:14 AM   #10
Rewards Points: 710
If I use a waterproof membrane, such as Kerdi, between the tile and cement board, should my insulation batts be faced, or have the facing removed?
And, Durock, Wonderboard or Hardibacker??
Need advice RE: purging air from baseboard hot water heating system mikenri HVAC 2 01-19-2011 07:17 PM
Open Hydronic Heating System... how / need to bleed? MtnMan7 HVAC 1 11-19-2010 03:51 PM
New House, new system, poor cooling Faulknertw HVAC 15 07-08-2008 10:06 PM
Size A/C system properly 70stang HVAC 1 03-26-2006 07:22 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 10:56 AM
