Waterproofing Shower Pan To Cement Board - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-15-2019, 08:11 PM   #1
Rewards Points: 100
waterproofing shower pan to cement board
hey there.
i'm installing a frameless glass walled shower with fibreglass pan.
i attached the picture from the manual.
if i'm using waterproofing membrane for the cement board walls, how exactly do i waterproof the area of the pan that touches the walls? do i put a strip of the membrane along the whole shower pan that covers the whole seam?
thanks very much for the help!
waterproofing shower pan to cement board-screen-shot-2019-04-15-5.03.02-pm.png
godblsmnymkr is offline   Reply With Quote
Old 04-16-2019, 06:06 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 1,340
Re: waterproofing shower pan to cement board
What membrane are you using? You will set your CBU directly on the top lip of the pan, and any membrane you use will extend over it to the first ledge, as will your tile. The tile will jump the gap and will prevent wicking of water. Not sure if that answered your question or not.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 04-16-2019, 07:30 PM   #3
Rewards Points: 100
great answer ty. we havent decided on membrane yet.
Old 04-16-2019, 09:58 PM   #4
Rewards Points: 100
in the picture from the manual, it shows the backerboard going all the way to the floor, then the pan backing into it. is this ok to do as well in terms of waterproofing and tiling?
couldnt you just silicone the tile wall to the shower pan flange?
thanks!
Old 04-17-2019, 05:28 AM   #5
retired painter
Rewards Points: 1,836
I wouldn't want to rely on caulking [which can fail] to keep water from getting behind/below the pan. As Larry said, the cement board needs to be above the pan so if water got back there it will still drain into the pan.
mark sr is online now   Reply With Quote
Green-board vs. Cement board for shower walls -- What does the code say? 2md General DIY Discussions 5 01-21-2019 08:10 PM
Using Cement Board for Shower Base PKC General DIY Discussions 2 12-17-2015 09:48 AM
Mortar vs. Cement Board Shower Curb costgeek Tiling, ceramics, marble 5 04-07-2015 11:43 AM
Waterproofing tiled shower walls. areusleepy Tiling, ceramics, marble 13 05-20-2014 07:08 AM
how to hang plastic behind shower cement board 4just1don Building & Construction 2 07-22-2011 12:34 PM
