DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Kitchen & Bath Remodeling (https://www.diychatroom.com/f80/)
-   -   waterproofing shower pan to cement board (https://www.diychatroom.com/f80/waterproofing-shower-pan-cement-board-657375/)
godblsmnymkr 04-15-2019 07:11 PM
1 Attachment(s)
hey there.
i'm installing a frameless glass walled shower with fibreglass pan.
i attached the picture from the manual.
if i'm using waterproofing membrane for the cement board walls, how exactly do i waterproof the area of the pan that touches the walls? do i put a strip of the membrane along the whole shower pan that covers the whole seam?
thanks very much for the help!
chandler48 04-16-2019 05:06 AM
Re: waterproofing shower pan to cement board
What membrane are you using? You will set your CBU directly on the top lip of the pan, and any membrane you use will extend over it to the first ledge, as will your tile. The tile will jump the gap and will prevent wicking of water. Not sure if that answered your question or not.
godblsmnymkr 04-16-2019 06:30 PM
great answer ty. we havent decided on membrane yet.
godblsmnymkr 04-16-2019 08:58 PM
in the picture from the manual, it shows the backerboard going all the way to the floor, then the pan backing into it. is this ok to do as well in terms of waterproofing and tiling?
couldnt you just silicone the tile wall to the shower pan flange?
thanks!
mark sr 04-17-2019 04:28 AM
I wouldn't want to rely on caulking [which can fail] to keep water from getting behind/below the pan. As Larry said, the cement board needs to be above the pan so if water got back there it will still drain into the pan.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
