Waterproofing Membrane Thickness? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-14-2017, 08:05 PM   #1
Waterproofing membrane thickness?
I am working on my shower stall and just laid down my waterproofing membrane (TEC Crack and Waterproof Membrane). Problem is I didn't use a gauge to confirm the thickness of the membrane while wet. I used the flat edge of a 3/16" V trowel to apply and spread the membrane material across the walls for both applications (second was applied perpendicular to the first)
I used (2) buckets that "should" cover 50sqft each. The walls total area is approximately 60-62sqft.
Is this enough or do I need more on the walls?
Gi49336 is offline   Reply With Quote
Kryton krystol internal membrane (KIM) foundation waterproofing 6fthook Concrete, Stone & Masonry 10 04-21-2015 08:06 PM
Why I can't use thin-set mortar over RedGard waterproofing membrane? sukhenkoi Kitchen & Bath Remodeling 9 03-16-2013 02:39 PM
What to put under the waterproofing membrane. TurboDIYer Flooring 22 01-27-2012 09:21 PM
Delta waterproofing membrane RINAIL Building & Construction 2 03-30-2008 09:52 AM
