Want To Remove Caulked On Showerhead - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By jmon
  • 1 Post By Canarywood1
  • 1 Post By mark sr
Old 04-14-2018, 09:42 AM   #1
Rewards Points: 136
Want To Remove Caulked on Showerhead
Bought new showerheads and went to unscrew old ones. Previous owner had used caulk on threads. Will not budge. Cannot believe they did this!
I sprayed WD-40 and used wrench to unscrew them. No luck.
Is there anything I can use on this to loosen old caulk? I am trying to avoid removing shower pipe. Thanks.
LadeeDIY is online now   Reply With Quote
Old 04-14-2018, 10:00 AM   #2
Rewards Points: 2,100
Re: Want To Remove Caulked on Showerhead
Use two wrenches. Wrap cloth around shower head pipe and grip with channel locks so you don't destroy pipe coming out of the wall. Then use a cresent wrench on shower head and turn ccw. Sometimes turning clockwise a little helps break the sediment as well. You need leverage because of all the sediment and caulk.
Another suggestion; Scrape what you can off. Try some pb blaster, or white vinegar in a plastic bag and and wrap it around the whole area leave for the night. Try again next day. Jut a suggestion.
Hope you get it off soon.
LadeeDIY likes this.
jmon is online now   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
LadeeDIY (04-14-2018)
Old 04-14-2018, 10:45 AM   #3
Rewards Points: 1,030
Got a heat gun, it will soften the caulk and ease the removal.
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
Old 04-14-2018, 10:58 AM   #4
retired painter
Rewards Points: 1,310
The first thing I'd do would be to carefully cut the caulk, maybe scrape some off with a plastic putty knife. Definitely wrap it with a rag prior to using any wrench/pliers.
mark sr is online now   Reply With Quote
The Following User Says Thank You to mark sr For This Useful Post:
Old 04-14-2018, 06:24 PM   #5
Rewards Points: 17,882
Caulk should not be an issue, use a longer wrench.
Old Today, 05:29 PM   #6
Hi we’re you able to find a fix I just moved in to my first home and have also discovered the same issue nothing’s working to remove it
AmberDoesIt is online now   Reply With Quote
Old Today, 05:37 PM   #7
Rewards Points: 136
Hi, I did resolve my problem. I sprayed WD40 onto the caulked threads. I let it set for 10 minutes and moved the shower head gently with a wrench. I repeated this several times. The shower head progressively moved a little bit more each time. Then finally I could unscrew the whole thing. I put on the new shower head no problem. I did not caulk the new one. Works fine and no leaks.
Tags
remove caulk , shower head
Want to remove wall in kitchen, possible? mikereno1 Building & Construction 7 11-11-2016 12:06 PM
can i remove Amitabh Building & Construction 0 06-08-2016 06:42 PM
How to remove shower pan? timnancyk Plumbing 17 01-11-2016 03:06 PM
need to refinish me pressure treated deck AND remove cabot SPF - NEED INPUT Kirchf Painting 0 05-27-2015 11:19 AM
replacing showerhead lindapalmbay Plumbing 2 01-23-2015 09:46 AM
