Wall Tile: Spacers Or Butt Together? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-22-2012, 04:27 PM   #1
Rewards Points: 111
wall tile: spacers or butt together?
I am going to be tiling a corner shower and was curious what your thoughts were on spacing the tiles (16x16) or not. Also, should I use sanded or standard grout?
dwcopple is offline   Reply With Quote
Old 04-22-2012, 04:56 PM   #2
The choice of spacing is really a design question so you have a few options. Generally on small tile the edge will have two small bumps that act as built in spacers. You then only need to butt them together. On larger tile, like you are using, the edge is flat so you choose your own spacing.
Typically, you want the spacing as small as possible given the natural differences in size between the different tiles.
I am doing my tub surround now and using a big tile, 12x24. I am spacing at about 3/32's or just under 1/8.
As for grout, narrow spaces of 1/8" you use non-sanded grout.
derf36 is offline   Reply With Quote
replace wall tile without damaging floor tile bruswain Flooring 3 05-21-2011 06:29 AM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Tiling Shower: Decorative tile thicker than Wall tile digexpressions Remodeling 11 06-08-2008 05:49 PM
Tile floor or wall first? LX8850 Flooring 3 08-30-2006 12:01 AM
