Wall For Rear Of Tub. - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By arthall111
Old 12-20-2016, 04:49 AM   #1
Rewards Points: 14
Wall for rear of tub.
I have a tub with 2 walls,L shaped shower curtain. I want to put a rear wall but toilet is placed snuggled behind it . thinking of building off rear ledge of tub. Possibly glass blocks (probably too wide). Any ideas??
Sent from my LG-V410 using Tapatalk
arthall111 is offline   Reply With Quote
Old 12-20-2016, 06:10 AM   #2
Rewards Points: 1,054
Re: Wall for rear of tub.
Pics or an diagram would help. Not sure how your layout is.
clarenceboddick is offline   Reply With Quote
Old 12-20-2016, 07:39 PM   #3
Rewards Points: 14
Old 12-20-2016, 07:40 PM   #4
Rewards Points: 14
Old 12-20-2016, 07:54 PM   #5
Ok, how many inches from the outer edge of the tub to the closest part of the toilet?
Old 12-20-2016, 09:25 PM   #6
Rewards Points: 14
Like 8 or 9,but would like to come off back top edge of tub so toilet isn't crammed
Old 12-20-2016, 09:43 PM   #7
Do you know if the tub is cast iron, fiberglass or sheet metal?
Old 12-22-2016, 03:31 AM   #8
Rewards Points: 14
Cast
Old 12-22-2016, 07:09 AM   #9
Cast iron is plenty strong enough to support a glass block wall. You could just build up a wall from the edge of the tub.
You could make the bottom a transition from a curved shape on the inside to match the tub to squared off to match the glass block. You could use white tiles, like a mosaic on the inside that is easy to curve. On the outside, you could just use something different as that is more square. I'd probably cast my own cement transition, or maybe cut down some solid blocks or bricks to fit. I wouldn't use wood, even pressure treated.
Old 02-05-2017, 01:44 AM   #10
Rewards Points: 14
Old 02-05-2017, 04:52 AM   #11
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,278
I would use tempered glass, two pieces siliconed together at the 45 corner.
Set them on the tub rim and silicone into place.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Old 02-05-2017, 06:09 AM   #12
Rewards Points: 14
What do you mean. Two pieces siliconed together?
Old 02-05-2017, 06:54 AM   #13
123pugsy's Avatar
2 pieces if you wanted to come all the way to the front edge, turning the corner at that 45 corner.
You could stop short of that and just use one pain on the end and be done.
You would still need an "L" shaped curtain rod.
Myself, I would try to figure out how to get glass on the end so I could install some sliding doors as well.
Old 02-10-2017, 02:28 PM   #14
Rewards Points: 14
Decided to use 2x4 wood notched in half from tub to floor. Backer board inside. Drywall out. Any concerns or ideas appreciated
123pugsy likes this.
surface drainage above a retaining wall Benjamin5 Landscaping & Lawn Care 4 09-26-2015 02:44 PM
Load Bearing Wall? Master Brian Building & Construction 3 06-05-2015 10:32 PM
Creating doorways/supporting wall issues NWVintage Remodeling 2 12-19-2012 03:19 PM
Retaining wall work-- what approach? emcelvaney Landscaping & Lawn Care 2 09-24-2012 07:49 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
