Wall Mounted Range Hood - Kitchen & Bath Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-16-2015, 11:05 AM   #16
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,274
Originally Posted by mailbox14 View Post
Thanks Pugsy.,
Wish me luck
Good luck!
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is online now   Reply With Quote
Old 12-26-2015, 11:37 AM   #17
Working at it
There seem to be a few suggestions that are missing the obvious. The range hood comes with a bracket to make it easier to install. It means you are not trying to hold up a 125 lb thing while trying to screw it to the wall. You can drill holes in the bracket where you need or want them. Mount it securely and the hood just hooks on.
I put a 120 lb 80" tv over my fireplace on a wall with NO studs. It is a SIP wall, 6-1/2" thick. I just ran bolts all the way through the wall and through a panel of 5/8" plywood slightly larger than the bracket. Long boots, washers and my own 250+ lbs can hang on that bracket.
Standu is offline   Reply With Quote
range hood duct NealTX HVAC 6 08-14-2011 12:12 PM
Range Hood venting bket HVAC 4 02-19-2011 07:12 AM
range hood wall cap/exhaust diameter nocsec Appliances 3 01-03-2011 09:03 PM
Backdraft, Cold Air and Ice from Range Hood and Bath Fan Rusty N HVAC 13 08-19-2010 07:00 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
