Is This Wall Cabinet Install A Problem - Kitchen & Bath Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-28-2015, 10:26 AM   #16
Rewards Points: 866
Originally Posted by Wild Willard View Post
1. Should I insist that they take the small cabinet down, open the wall, and insert a nailer or stud of some sort that will enable a solid installation.
Not required, these are properly secured, very typical cabinet installation. If the small cabinet's face frame is secured to another cabinet's face frame all the cabinets act as a unit.
There is no cabinet to either its right or left. It hangs alone.
Check the Cab Mnf's installation information, to be sure.
Duh. I never even thought that there were manufacturer's installation instructions for the cabinets.
2. Should they be using some other sort of screw system to affix the cabs to the wall?
They appear to be truss head - washer head screws which are correct and appropriate for this application, expeically through 1/2" plywood. 2 1/2" long screws are typical and having 1.5" of screw into stud is fine.
3. Is there going to be a problem with the way the cabs were notched for the wiring?
Once again very typical technique and standard practice in most areas.
Thanks for the explanations.
Klawman is offline   Reply With Quote
Old 09-28-2015, 10:40 AM   #17
Rewards Points: 118
Stand alone - did they run a screw through the top close to the face frame into the drop or ceiling framing?
The cabinet needs to be secured as not to rotate/twist on the wall fastening points. Often if there is trim above and that is nailed into the cabinet and framing, that may adequately secure the cabinet in that regard.
Wild Willard is offline   Reply With Quote
Old 09-28-2015, 10:55 AM   #18
Rewards Points: 866
The cabinet actually hangs below a soffit running along that wall and I am pretty certain there isn't anything they could have ran a screw into other than the one vertical stud. They ran one screw through the cab back about an inch below the face frame and a second screw through the back below the bottom of the cabinet. Both are screwed into that one stud. When I questioned if the cabinet was secure enough and why it wasn't secured to another stud, they said there was no other stud to screw into and they placed a third screw into the same stud just about 10" above the bottom of the cabinet.
I don't see how it could rotate on the wall
My comments in bold
Old 09-28-2015, 12:27 PM   #19
Rewards Points: 118
Sounds like it's secure then
The Following User Says Thank You to Wild Willard For This Useful Post:
Klawman (09-28-2015)
Sunken living room wall problem.. Max5150 Building & Construction 8 02-15-2012 06:30 AM
Problem with in wall dryer duct. darsunt HVAC 5 02-02-2012 12:23 PM
How do you install this metal edge on the wall? noone Tiling, ceramics, marble 2 12-15-2011 12:03 PM
Copper Y fitting and cabinet install brneilly Plumbing 4 06-30-2011 09:13 AM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
