Is This Wall Cabinet Install A Problem - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 09-26-2015, 08:58 PM   #1
Rewards Points: 866
Is this wall cabinet install a problem
Despite my contractor's assurances that these two wall cabinets are installed secrrely, I have come to have little faith in its work and expect it to do the cheapest work it can get away with (despite the fact that it is a relatively expensive job."
Before I complained, their installer hung the two with two screws for the smaller left cabinet and four for the larger right cabinet. Instead of using countersunk screws that were then capped with plug for appearances, the shiny ones with washers depicted were used.
The installer said he could only affix the small right hand cabinet to a single stud as the nearest other stud was 4" to the right of the cabinet. I am wondering why the remodeler didn't have a horizontal nailer inserted between the studs while they had the wall opened up for other work.
I am also concerned that they notched the plywood backing just under the main body of the cabinet to make an opening for the wiring to be connected up to under cabinet lighting.
I guess my questions are:
1. Should I insist that they take the small cabinet down, open the wall, and insert a nailer or stud of some sort that will enable a solid installation.
2. Should they be using some other sort of screw system to affix the cabs to the wall?
3. Is there going to be a problem with the way the cabs were notched for the wiring?
I may be being picky, but if there is a problem it is best to take care of it before that wall is covered with backsplash tile.
I am told that the backs of those cabinets are 1/2" plywood.
Some pics are attached. Thanks. If this is fine as is, cool, but a lot of the stuff they tried to get away with was crap and with this forums help it looks like they fixed a lot of things (but sometimes only having after going to the city).
Is this wall cabinet install a problem-20150926_180502.jpg   Is this wall cabinet install a problem-20150926_181050.jpg   Is this wall cabinet install a problem-20150926_180852.jpg   Is this wall cabinet install a problem-20150810_105403.jpg   Is this wall cabinet install a problem-20150926_190353.jpg
Klawman is offline   Reply With Quote
Old 09-26-2015, 11:06 PM   #2
Rewards Points: 5,348
The wall(sheetrock) should have been removed and blocking installed behind where the wall cabinets are being installed. That way you can put the screws in where they support the cabinets instead of just where the studs happen to be. Typical numb nuts contractor install.
Ron
B. Franklin 1759
Old 09-27-2015, 12:02 AM   #3
Rewards Points: 866
Thanks Ron. That, as I typed my post, was a gimme. Would you think there is likely to be problems down the road if some blocking isn't installed?
BTW, the same contractor screwed up am sink installation for the second time.
Old 09-27-2015, 07:24 AM   #4
Retired Moderator
Rewards Points: 7,174
If the cabinets were good quality--and screwed into the back stiffener (usually 2" wide--at the inside top and bottom of the back panel) they might be alright---
Using wall anchors into the drywall is also acceptable for a smaller cabinet that is secured to at least one stud---
Old 09-27-2015, 07:28 AM   #5
Super Moderator
Gymschu's Avatar
Rewards Points: 6,770
What's with the wiring in the final picture? What a cobbed up mess that appears to be.
"In the heat of battle, my father wove a tapestry of obscenity........."
Old 09-27-2015, 07:46 AM   #6
Rewards Points: 6,897
I got to agree with the others. It sounds like a half butt install.
If they are surface mount 4 toggle bolts in each will hold them and all contents to securely attached drywall. If recessed they need at lest 2 screws at the top screwed into the framing and I prefer 4. Side screwed into framing is also acceptable.
If that notch is into the ledger frame board (the top and bottom band that adds the strength) of the cabinet then I would be very concerned. Actually I would probably not accept the job.
Sorry, I could not be more positive.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 09-27-2015, 08:07 AM   #7
ZZZZZ's Avatar
Rewards Points: 2,188
Also check and see what kind of screws they used. (and how long.)
"Cabinet screws" really do hold very well.
http://www.homedepot.com/p/GRK-Faste...3079/203525221
ZZZZZ is online now   Reply With Quote
Old 09-27-2015, 04:02 PM   #8
Rewards Points: 866
I don't know what you mean by a back stiffener. The back of the cabinets is 1/2" plywood. They are then mounted on the sheet rock. I believe the large wall cabinets have 4 screws affixed into studs at the top and bottom. The ones depicted is the small cabinet on the other side of the range.
As for quality, they aren't the best but not supposed to be junk. They are Dynasty by Omega, a subsidiary of Masterbrand Cabinets.
Old 09-27-2015, 04:08 PM   #9
Rewards Points: 866
Most of that wiring is from the original build 20+ years ago. Some of the white Romex is wiring for cabinet lights temporarily wrapped about other wires. I aam nor electrician, but the electrical part of that wall seemed alright to me with the exception of how the NM is then passed through holes in the drywall and a notch in the bottom of the cabinet. The last picture shows what I mean.
http://www.diychatroom.com/attachmen...926_190353.jpg
The Following User Says Thank You to Klawman For This Useful Post:
Gymschu (09-27-2015)
Old 09-27-2015, 04:18 PM   #10
Rewards Points: 866
Don't apologize for negativity. This is the time to fix things; before the backsplash is tiled.
That isn't ledger board but the lower part of the box's 1/2" back. The screws may be some kind of cabinet screw. They take a square driver rather than a phillips or common.
Old 09-27-2015, 04:23 PM   #11
Rewards Points: 866
I already asked and I believe the length was 2 inches. Perhaps longer
Old 09-27-2015, 08:24 PM   #12
If you are positive the cabinet has a 1/2" back (some modern ones do) and not a board frame support (ledger board probably isn't the correct term) with 1/4 back then that cut isn't as bad.
Colbyt
Old 09-28-2015, 12:05 AM   #13
Rewards Points: 866
Without ripping the cabinet apart, I can't be positive but this is a picture taken of where the bottom of one side of the cabinet meets the wall. Those plies measure 1/2" and insert into a notched section of the one side of the cabinet.
The following three pictures may better explain the construction. The first is the left corner where it meets the wall. The second a view of the cabinets entire bottom, and the third shows where the right side of the cabinet mates with the face frame
Is this wall cabinet install a problem-20150927_213349.jpg   Is this wall cabinet install a problem-20150927_213649.jpg   Is this wall cabinet install a problem-20150927_213429.jpg
Old 09-28-2015, 07:44 AM   #14
It sure looks like you are correct.
Colbyt
The Following User Says Thank You to Colbyt For This Useful Post:
Klawman (09-28-2015)
Old 09-28-2015, 09:15 AM   #15
Rewards Points: 118
Not required, these are properly secured, very typical cabinet installation. If the small cabinet's face frame is secured to another cabinet's face frame all the cabinets act as a unit.
Check the Cab Mnf's installation information, to be sure.
They appear to be truss head - washer head screws which are correct and appropriate for this application, expeically through 1/2" plywood. 2 1/2" long screws are typical and having 1.5" of screw into stud is fine.
Once again very typical technique and standard practice in most areas.
Wild Willard is offline   Reply With Quote
The Following User Says Thank You to Wild Willard For This Useful Post:
Sunken living room wall problem.. Max5150 Building & Construction 8 02-15-2012 06:30 AM
Problem with in wall dryer duct. darsunt HVAC 5 02-02-2012 12:23 PM
How do you install this metal edge on the wall? noone Tiling, ceramics, marble 2 12-15-2011 12:03 PM
Copper Y fitting and cabinet install brneilly Plumbing 4 06-30-2011 09:13 AM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
