Walk In Shower - Kerdi Vs Dry Pack - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-06-2017, 11:59 AM   #1
Rewards Points: 40
Walk In Shower - Kerdi vs Dry Pack
I am planning my bathroom remodel and I will be building a neo shaped walk-in shower. If it has a glass door is it a "walk in"? Anyway, because of the shape the Kerdi 48 x 48 base would have to be cut to suit. Is that a good idea or should I make my own with dry pack mortar? Also, what's the consensus on the Kerdi curb at the door? Is it worth it? Of the neo shape, two walls are exterior walls and two will be tiled half walls with glass the rest of the way up. Do I put a Kerdi curb at the door or a 2 x 4 curb wrapped in Kerdi membrane?
montrealmike is offline   Reply With Quote
Old 11-06-2017, 03:03 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 748
Re: Walk In Shower - Kerdi vs Dry Pack
Hi Mike,
Either way will work as long as the drain is fairly close to center. The foam curb is excellent, makes things easier.
If you build your own curb, remember you can not apply Kerdi direct to lumber.
Tell us about your experience in building showers.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 11-12-2017, 09:18 PM   #3
Rewards Points: 150
I'm doing a dry pack shower pan with Kerdi membrane.
Kemper100 is offline   Reply With Quote
Tags
dry pack , kerdi , shower base
Shower Tile with Schluter Kerdi System tstorm Tiling, ceramics, marble 7 10-03-2017 07:45 PM
KERDI Shower Systems Kemper100 Kitchen & Bath Remodeling 18 09-25-2017 05:31 PM
Moisture-proofing kerdi shower walls tdarlingt Kitchen & Bath Remodeling 2 05-15-2011 06:11 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Kerdi Basement Shower ldogg Flooring 7 09-13-2009 08:28 PM
