Wainscoting On Bathrrom Walls, Then Tile Floor? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 09-21-2013, 08:10 AM   #1
Wainscoting on Bathrrom Walls, then tile floor?
I about about to install wainscoting in the bathroom, I have not yet installed the tile floor. I am assuming this is the way to go. However the chair rail groove is twice the width it the wainscoting itself. Is this normal, or did I simply order the wrong chair rail? Also, the baseboard also has a groove into which, supposedly, the wainscoting sits. I assume that must go in prior to wainscoting, no?
Please help ASAP!
cttom81464 is offline   Reply With Quote
Old 09-21-2013, 08:27 AM   #2
Retired Moderator
Rewards Points: 7,174
Typically the floor is done first and then the trim work----however ,If you must do the walls first--figure out how the flooring will be tucked under--or butted up against the new wainscot---
As to your chair rail---you may have ordered the wrong profile----pictures always get the best answers---Mike------
Old 09-21-2013, 10:48 AM   #3
Question?
Is wainscoting on the walls considered trim work?
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Ceramic Tile Floor Info Help RichardZ Tiling, ceramics, marble 36 07-26-2012 08:33 PM
Should I remove tile floor after minor flood? dan1980 Flooring 5 05-24-2012 03:48 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 01:46 PM
Bathroom Floor - Tile - floor Height - Flange DoItYourSelfer5 Flooring 2 12-15-2008 06:18 PM
