Vinyl Shower Walls, Cut To Size, Glue To Studs, Caulk Joints? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-15-2015, 09:11 PM   #1
Rewards Points: 213
Vinyl shower walls, cut to size, glue to studs, caulk joints?
Need to insulate behind a tile shower. Might rip off the exterior siding and go from there but would rather rip the tile off and insulate from there because the tile might be leaking also. And then I want to put a panel thing up. It's probably a standard sized tub and shower. I know they have kits but I think the tub is staying so I don't know if the kit would make the right connection with the old tub. Also, the ceiling is tile and only about 7 feet tall so I don't know if the wall kit will join the ceiling the right way. I think they might be designed to install drywall/tile over the top edge of the wall and then that tile/drywall is what goes into the top ceiling corner.
So is there something I can get from lowes or home depot that I can just cut to size, glue to the studs, and then caulk all the joints after taking the three tile walls off? TY
gunner666 is offline   Reply With Quote
Old 07-15-2015, 09:58 PM   #2
Rewards Points: 213
something like this is all I need.
Hope I can find it at lowes/HD because need it soon.
Only question I have is what kind of backer board should I put since I'm ripping out the existing tile walls down to the studs? Cement board (wonderboard or what brand?)or just drywall? Do I even need mold resistant bathroom drywall if I use drywall.
Besides for durability, do I even need a backer board and can I just glue this to the studs?? It depends on how the face of this matches up with the rest of the bathroom wall but maybe I don't even need to bring the wall out further with a backer board.
Old 07-16-2015, 05:29 AM   #3
Retired Moderator
Rewards Points: 7,174
You need a backer---green board should be fine---
Old 07-16-2015, 05:53 AM   #4
Rewards Points: 52
I would go with cement board and coat it with Redgard. In your other thread - you mentioned it was a rental. You wont be around to inspect the caulked joints.
tribe_fan is offline   Reply With Quote
Old 07-16-2015, 06:05 AM   #5
Rewards Points: 6,897
This is just an opinion based on limited experience. The units that are sold with tubs work fairly well. The add on stuff for older tubs almost never does.
You will need a backer behind the surround unless it is part of a tub + surround kit. There isn't much difference in cost between green board and Hardie.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is online now   Reply With Quote
Waterproofing tiled shower walls. Blondesense How To Guides 22 06-06-2014 01:29 PM
Large Porcelain Tiles for Shower Walls BigJim Flooring 138 02-27-2013 08:23 PM
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 07:22 AM
Kohler shower door, tolerances, not sure which size to pick mslide Kitchen & Bath Remodeling 2 12-04-2009 11:08 PM
Rotting shower walls PICTURE Sarah24 Kitchen & Bath Remodeling 6 05-10-2009 12:09 AM
