DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Kitchen & Bath Remodeling (https://www.diychatroom.com/f80/)
-   -   venting bathroom out wall (https://www.diychatroom.com/f80/venting-bathroom-out-wall-48617/)
mrtmills 07-11-2009 11:44 AM
Hello,
I have an old double brick house with a flat roof. I want to vent my bathroom out the wall to avoid putting a hole in the new roof membrane. The problem is that the wall is not insulated leaving me about 2 inches of space between the inside brick and plaster (the plaster is furred out on 1x2s). Is there a skinny fan out there somewhere? I would prefer not to build the fan box out of the wall for aesthetics. When I talk to locals in the hardware stores they look at me like I am crazy, but every house is this entire city is double brick, flat roof, no insulation so someone has to have tried this.
thanks a lot.
Just Bill 07-13-2009 06:45 AM
Some local codes allow that, some do not, check local authority.
7echo 07-13-2009 08:18 AM
An HVAC supply house will have a fan, lots of guys use Greenheck, but that is just one brand option. A plumbing or HVAC supply house will have more options and maybe some suggestions.
Definitely check the codes. You can spray foam the cavity to help seal it.
I understand about the visual aspect, but if you can get over that there will be more common options in the wall mounted style blower.
mrtmills 07-13-2009 08:52 PM
Thanks, I will check the code, and the HVAC suppliers.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
