Vapor Or Not To Vapor? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-14-2016, 12:07 PM   #1
Rewards Points: 22
Vapor or not to Vapor?
Redoing the bathroom and replacing the bath tub enclosure with a tiled wall. The plan was Durock the bath tub walls and the waterproof with Redgard. But I have seen some people say you need to vapor barrier behind the Durock as well and others say it's not necessary if you seal the rock. Some say it depends on the board - Durock you don't need vapor, Hardibacker, you do need the vapor barrier. There doesn't seem to be a straight answer on it.
To add to it, one of the walls is an exterior wall and I've read you should vapor it anyway and others again saying no. Others suggesting it depends on the insulation - if it's faced insulation it already has a vapor barrier on it so plastic is not needed.
Any guidance? Thanks.
Sydmax is offline   Reply With Quote
Vapor barrier is not a air barrier make! It is a vapor retarder Nailbags Insulation 4 04-21-2014 07:02 PM
Knee walls and vapor barrier duffman56 Insulation 12 12-14-2013 10:46 PM
Basement Bathroom substrate and vapor barrier? ikonone Drywall & Plaster 1 08-09-2013 10:38 PM
Bathroom insulation question Joe Tilghman Insulation 9 02-05-2012 01:12 PM
Clearance of Duct to Vapor Barrier mkturn HVAC 0 02-21-2011 12:41 PM
