Uneven CBU Seams - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By godblsmnymkr
  • 2 Post By chandler48
Old 04-29-2019, 07:18 PM   #1
Rewards Points: 92
Uneven CBU seams
doing first time bathroom renovation so i'm making some mistakes while I go.
I did not put a stud in behind the 2 seams in the pictures. they are not flush together by about 1/3" at the worst spots. some spots are flush.
other than removing the cement board and putting a stud in can I thinset the seam, waterproof it with RedGuard and then put on coats of drywall mud until the seam is flush enough?
FYI I'm tiling over the walls in question with 12x24" tile so my room for error is less than usual.
thanks so much
PS sorry those pics should be turned 90degrees right
godblsmnymkr is offline   Reply With Quote
Old 04-29-2019, 07:35 PM   #2
retired framer
Rewards Points: 18,758
Re: Uneven CBU seams
What is the most distance to the stud.
On the first one will you tile over to the edge of the window.
Do not use flat bottom gables with scissor trusses.
Old 04-29-2019, 09:39 PM   #3
Rewards Points: 92
thanks for replying.
distance from seam to nearest stud is only 4-5 inches. i'd have to measure it.
i'm thinking best solution is just apply thinset until i can make the seam flush enough to tile on.
my dads in the business and thought because its cement board and pretty stiff it should hold up ok. he thought i should use drywall mud to cover the seam and make it flush but that doesnt sound right if i'm going to tile over it later.
Nealtw likes this.
Old 04-30-2019, 06:02 AM   #4
Naildriver
chandler48's Avatar
Rewards Points: 3,660
Do it right, remove the CBU, install a stud or other support behind the edges and reinstall the cbu. You are at the stage now that you can not afford to cheap out. Drywall mud behind tile will be a disaster, so stick with the normal methods of sealing the joints.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 04-30-2019, 09:02 AM   #5
Rewards Points: 92
thanks for the reply Chandler.
do you think using a couple of layers of thinset to smooth out the joint is not a good option?
Old 04-30-2019, 03:34 PM   #6
Naildriver
chandler48's Avatar
On a wobbly unsupported edge of CBU, absolutely not.
Larry......
Old 04-30-2019, 11:22 PM   #7
Rewards Points: 92
thanks for your honest replies chandler. i'll put the studs in this weekend.
allure flooring coming up at seams & corners Mavis Flooring 23 12-23-2018 04:59 PM
Cracks in seams of new drywall - help - why? bajafx4 Drywall & Plaster 21 04-05-2016 08:06 AM
Drywall seams cracking all over dhd42 Drywall & Plaster 8 02-03-2015 10:02 AM
Ceiling seams wwkayaker Drywall & Plaster 9 10-25-2014 12:19 PM
uneven seams with hardibacker after thinset and screws wpeckler Tiling, ceramics, marble 0 03-03-2011 01:25 PM
