Under Mount Sink - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-22-2017, 10:30 AM   #1
Rewards Points: 77
Under Mount Sink
I'm building a 48 inch bathroom vanity out of some tiger maple. The top will be tiger maple too. I've ordered an oval under-mount sink from the supply house. I've never installed one before but it doesn't appear to be that complicated a deal. I'd like the top to be 5/4 once it is thickness planed and cleaned up. Is that too thick for an under-mount or will I be okay? Thanks
RMCarner is offline   Reply With Quote
Old 05-22-2017, 10:48 AM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,020
Re: Under Mount Sink
Different undermounts use different clips/rails and mounting systems.... but I can't think of any system where your counter DEPTH/THICKNESS would make a difference.... unless you had strange clearance issues.
Check your undermount system.
MTN REMODEL LLC is offline   Reply With Quote
Old 05-22-2017, 05:53 PM   #3
Rewards Points: 898
Wood countertop for a vanity?
BIG Johnson is offline   Reply With Quote
Old 05-23-2017, 05:18 PM   #4
Two Knots's Avatar
Rewards Points: 3,875
We made a wood 48" bathroom vanity top several years ago
with 8/4 QS white oak.
We re-used our old sink (a hex sink) cause I liked the sink
and also wanted a big sink.
The iunder mount sink is going to look great with the wood top.
We did have to refinish it once as the part under the soap dish
got stained. We had to take it apart, bring it outside and sand it down.
You have to be careful with water splashes etc...
With the undermount sink you can sand it down on site and refinish it if necessary.
Two Knots is online now   Reply With Quote
Old 05-24-2017, 02:32 PM   #5
Two Knots's Avatar
Why am I such a thread killer?
Drain Route and Venting for new kitchen sink drain (window above sink) joemc3 Plumbing 12 11-05-2016 06:17 PM
hardware to mount mount pedestal sink amakarevic Plumbing 3 12-11-2014 07:22 PM
Suspended/Floating sink installation? How? techprincesse Building & Construction 3 11-21-2010 03:05 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
Caulking around kitchen sink deeaa Remodeling 8 07-13-2008 03:12 PM
