Under Kitchen Island Counter Top - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Chris616
Old 01-11-2020, 11:03 AM   #1
Rewards Points: 8
Under kitchen island counter top
Hi, what is usually underneath a kitchen island quartz countertop when finished? I just went thru a kitchen remodel nightmare for 6 of the longest months of my life! When I asked the contractor if they were going to just leave the plywood under the island the way it was, rough and unfinished, he told me " nobody is going to get on their hands and knees to look"? That might be true, but I will! Unbelievable... I have young grandchildren, that are about the same height as counters, and will probably stick toys or food in the gap? Any ideas?
Dezireev is offline   Reply With Quote
Old 01-11-2020, 11:06 AM   #2
Rewards Points: 146
Re: Under kitchen island counter top
Photos would be helpful to us. Not sure what the "gap" is that you're referring to, for example.
In answer to your question, though, the "finished" look is to use steel/aluminum supports in an area where there is an eating area overhang on an island. I assume that is where you're seeing plywood underneath.
Chris
Dezireev likes this.
Chris616 is offline   Reply With Quote
The Following User Says Thank You to Chris616 For This Useful Post:
Dezireev (01-11-2020)
Old 01-11-2020, 11:48 AM   #3
Rewards Points: 8
not sure how to insert a pic?
https://1drv.ms/u/s!ApVYc7kxhl6hnCgXO1W_zxzKcOFz
Old 01-11-2020, 11:55 AM   #4
Rewards Points: 8
https://1drv.ms/u/s!ApVYc7kxhl6hnBy_aM2cgXZMnf8d
not very good pics but there is about half or 1 inch of gap all the way around
Old 01-11-2020, 11:59 AM   #5
Rewards Points: 8
They glued down the quartz on top of the plywood that sat on cabinets?
Old 01-11-2020, 12:08 PM   #6
Rewards Points: 146
If you open the cabinet and look up inside you should be able to answer that question.
Here's how to insert pictures:
https://www.diychatroom.com/f114/how...-posts-205921/
If you want meaningful input from folks I think you'll need to spend a bit of time refining your photographic technique.
Chris
Old 01-12-2020, 09:21 AM   #7
Rewards Points: 404
His first picture is of the island corner overhang looking up from underneath. The underside of counter is typically not expected to be finished. The only exception is food/ hospital areas where no permeable substrates are permitted.(by code) What you are asking for is over and above what is expected.
Tymbo is online now   Reply With Quote
Old 01-12-2020, 09:36 AM   #8
Rewards Points: 1,764
I've heard that on the west coast they use 3/4" granite with a plywood substrate, and on the east coast they use 1-1/4" thickness granite with no substrate. This seems to back that up. I agree with the installer that as long as the bottom of the substrate is flush with the counter overhang, there is no problem. OP, if it really bugs you, have him paint it white.
huesmann is offline   Reply With Quote
Old 01-12-2020, 01:31 PM   #9
Rewards Points: 404
Stone comes in 2cm and 3cm thicknesses. It's not a East or West thing. some varieties come in both thicknesses, others don't. The edge detail/ thickness also determines what is used. If the built up edge calls for 1 1/2" thickness(nominal) 2cm is used with subtop and doubled up edges.
Old 01-13-2020, 03:01 PM   #10
Rewards Points: 630
If you wanted/needed something else other than what was done. This should have been indicated in the contract ahead of them placing the stone top onto the top of the cabinets. After the fact is a little late to be bringing this up. Now you have the cost of a new slab of quartz, plywood and steel supports.
We used flat bar stock steel as hang over support, but that has nothing to do with what the most part of the quartz counter rests. We placed our top on the top of a piece of antique furniture. I'm not concerned with what it looks like from underneath. All that can be seen is the bottom side of the quartz, and of course the 4 pieces of steel to support the over hang.
You may sand and paint the plywood. You could have specified in the contract to use A-B grade plywood. Turning the A side to the floor so that it is smooth. But would still need to be painted. This is something more personal preference as to what goes into your own home. You are the boss on any construction in your own home. The material you state to be used, will be used. If not, find a new contractor/company. But you have to let them know what you want before the work begins.
Andrew
Handy Andy In Mt Airy NC
HandyAndyInNC is offline   Reply With Quote
Old Today, 03:39 PM   #11
Rewards Points: 888
You can prime and paint it but I agree with the contractor that no one is every going to see it. Having children put gum under furniture is a separate problem altogether.
Calson is online now   Reply With Quote
