Uh Oh...kerdi Newbie Mistake? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 09-28-2014, 11:29 AM   #1
Rewards Points: 4
Unhappy
Uh oh...kerdi newbie mistake?
I am trying kerdi membrane in a small shower for the first time. I installed all new drywall - however - the existing (bordering) drywall is textured and the new stuff did not sit flush. So I transitioned (feathered) with joint compound. Was about 1/16 off - but now I have Joint Compound over about 12" of the new drywall on the edges.
Of course I now find out that joint compound is NOT good when installing Kerdi membrane / thinset. I now know I should have used shims (or thinset).
Am I looking at having to tear out the new drywall or is it possible to paint/prime the joint compound so it will bond with the thinset and kerdi?
Thanks in advance for the knowledge.
Schuby99 is offline   Reply With Quote
Old 09-28-2014, 02:39 PM   #2
Rewards Points: 2,630
I can't say how water proof the kerdi will remain. Many people seem to think you can't use kerdi on a sheetrock, but that is a puzzle since kerdi is claiming solid water proof membrane.
However, I think you can prime and use thinset over the compound. Prime and then paint red vapor barrier over the area (I forget the name). Although I used Durock, I did the transition with compound and red paint on VP. Then used thin set for 3x12 marble tiles. No problem 5 years counting.
Before the cement boards, tilers were using thinset on sheetrock. I can't speak for longevity, but it does work.
carpdad is offline   Reply With Quote
The Following User Says Thank You to carpdad For This Useful Post:
Schuby99 (09-28-2014)
Old 09-28-2014, 02:51 PM   #3
Rewards Points: 4
Thanks for the advice.
Kerdi actually recommends drywall so I am not worried about the actual drywall. Just worried about the interaction between the joint compound and the thinset I will use to apply the kerdi.
Think I will try to remove as much of the joint compound as possible and then use your suggestion (prime/paint) what remains.
Thanks again
Old 09-29-2014, 03:11 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Thanks again
Paint over the joint compound with any of the liquid waterproofing membranes like Redgard. You'll be fine. You could also use an exterior primer paint or even shellac. Then install the KERDI.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
Schuby99 (09-29-2014)
Tags
joint compound , kerdi , paint
Bathroom Remodel 2nd floor ckrohn83 Kitchen & Bath Remodeling 78 10-01-2014 11:26 AM
Modified vs. Unmodified Thin Set for Kerdi Shower Install scotthu Tiling, ceramics, marble 2 09-22-2013 08:53 PM
Installing Kerdi board in bathroom JP's Dad Drywall & Plaster 3 04-02-2013 10:05 AM
Oh, The Decisions for Shower, Hot Mop? Kerdi? ddawg16 Plumbing 5 12-17-2012 09:33 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
