Type Of Cabinet Screws - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree7Likes
  • 2 Post By Yodaman
  • 1 Post By joecaption
  • 2 Post By Tymbo
  • 1 Post By MTN REMODEL LLC
  • 1 Post By CNT
Old 04-21-2018, 05:22 PM   #1
CNT
er... I aren't a Newbie.
Rewards Points: 454
type of cabinet screws
As putting up cabinets onto the wall, I plan to use this -> LINK <-
This one is Philips head, I may select the Star or whatever. I think 3" should be right length (common).
My question is which screws to use to connect the cabinets side-by-side face-frame (and fillers)?
Also, I really would like to HIDE the screw heads, so when opening the doors, screws shouldn't be noticeable. I have considered taking the hinges off and screw in there, but some said not to mess around with that. Some said to use stickers to cover it, but really?
I am guessing 3 screws per side for a 36" tall wall cabinets. And pre-drill holes to prevent splits.
If there was a thread about this, please post the links. I couldn't find a discussion about this.
CNT is offline   Reply With Quote
Old 04-21-2018, 05:48 PM   #2
Property Mgt/Maint
Rewards Points: 6,394
Re: type of cabinet screws
How about real cabinet screws
https://www.grkfasteners.com/products/cabinet/cabinet
I wouldn't worry about hiding the screws heads. You can not see them with the door closed. And when you open the door, the first thing you see is the whats inside, not hardware.
Also, most cabinets come with cabinet screws for hanging
SPS-1 and joecaption like this.
Yodaman is offline   Reply With Quote
Old 04-21-2018, 07:25 PM   #3
Rewards Points: 17,896
Most often I use trim head screws.
I also use this style clamp to make sure there tight together and the faces are flush.
I can perdrill and and install the screws without having to remove the clamp.
http://www.rockler.com/bessey-bes5811-cabinet-installation-face-frame-clamp?sid=V9146?utm_source=bing&utm_medium=cpc&utm _term=&utm_content={adtype}&utm_campaign=PL&utm_so urce=bing&utm_medium=cpc&utm_campaign=(ROI)%20Shop ping%20-%20Clamps&msclkid=4a9b3ed3b3391985e89a640866b42f75
Yodaman likes this.
Old 04-22-2018, 08:13 AM   #4
Rewards Points: 334
I agree with yodaman on the washerhead screws for mounting cabinets.
BTW this guy was in front of me at a stoplight yesterday:
Yodaman and akuhn235 like this.
Tymbo is offline   Reply With Quote
Old 04-22-2018, 11:28 AM   #5
RRH
Rewards Points: 1,322
I also agree with the washer head screws. Just 2 with be good enough. If it bothers you spray paint the heads before with a color that would be less noticeable.
Next would be trim head decking screws. And can order them in all different colors
RRH is offline   Reply With Quote
Old 05-06-2018, 12:17 PM   #6
CNT
Rewards Points: 454
I get it... this one below would be the ones I will use to bolt the cabinets onto the wall. (I was planning on 3" anyways, these 3-1/8" only comes in that large bulk package).
Now, for the side-by-side face-frame... correct me, these two below are made for that?
What's the difference with "RT" (Composite) and "FIN/Trim"? I would choose the "FIN/Trim". BTW, again, correct me, those are for side-by-side face-frame and they will connect/hold together tight? I am just wondering about the size of the trim head.
Old 05-06-2018, 01:08 PM   #7
CNT
Rewards Points: 454
-> LINK <-
Moderators, see what I mean? Now I can't "edit" to add one more question, but need to put another post... <sigh>
Anyway, the face-frame is 1-1/2" wide (meaning 3" when meld together). Should 2" be good length? I am assuming I would drive the trim head little past flush.
Old 05-06-2018, 01:56 PM   #8
jlhaslip's Avatar
Rewards Points: 708
Notice the second spirals on the head of the Composite screws just under the screw head?
That is designed to avoid the material mushrooming and allows for drawing the material tighter to the joisting. Not required for cabinets.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 05-06-2018, 02:54 PM   #9
CNT
Rewards Points: 454
Ahh. I didn't realize the second spirals thread was opposite screwing.
Old 05-07-2018, 09:46 AM   #10
CNT
Rewards Points: 454
Since no one is answering this... I called GRK and even these people couldn't make sure if those would work with FACE-FRAME. They repeat what was already noted on the back of the package. I guess I will give it a try (will test it on samples first). I was concerning about the squeezing holding power with the small trim head.
Old 05-07-2018, 10:35 AM   #11
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,062
WHAT..???????????????????????????????
That's what they are for, or at least can be used for.... face frame joinery.
They won't work for framless/euorpean cabinet style.
Yes... the trim head does diminish it's clampinjg power... but you'll be going into a hardwood frame.... if your worried about it, use a washer head GRK, or put more trim heads in......
You are the one that was worried about the screws showing...????
Oso954 likes this.
MTN REMODEL LLC is offline   Reply With Quote
Old 05-07-2018, 06:32 PM   #12
CNT
Rewards Points: 454
I am not worried about screws showing... just that if it can be hidden, that's preferred. Just me.
Old 05-07-2018, 07:03 PM   #13
Gosh... then use the trim heads.
I've used all sorts of scews from drywall/decking/trim/never bothered with GHK, for joining face frames.
If the cabinet has been shimmed and normally well attached, the face frame screws have little stress on them.. either pull-out or shear stress.
Now, for hanging the cabinets, there is where you want to pay attention to t
Old 05-07-2018, 09:36 PM   #14
CNT
Rewards Points: 454
Indeed, that I will use (as what GRK actually call those) the "Low Profile Cabinet (TM) Screws"
MTN REMODEL LLC likes this.
Type of screw should I use? brizzle Carpentry 20 04-04-2018 09:41 PM
Help Identifying Kitchen Cabinet Hinge Type MetalMan8008 Kitchen & Bath Remodeling 1 09-21-2014 04:24 PM
How many screws to mount a wall cabinet? AzJazz Carpentry 13 11-14-2011 08:58 PM
Wall cabinet mounted next to pantry cabinet ryan.kelly Carpentry 2 10-13-2011 07:50 AM
custom cabinet countertop dilemma: notch it or redo? mystic_cobra Carpentry 14 05-12-2011 10:35 PM
